Old 03-03-2008, 04:24 PM
Paul Kondzich Paul Kondzich is offline
What is this?
1950's house. What is this, it appears to be a cleanout because the bottom unscrews. The other question is, on the top there is a hole drilled in it for a condensate line. Other than the line just being stuffed in there, and an improper connection is there anything else wrong. Its not a cross connection is it???
Paul Kondzich
www.altitudehomeinspection.com
Old 03-03-2008, 04:50 PM
Jim Robinson's Avatar
Jim Robinson Jim Robinson is offline
Re: What is this?
It's a drum trap. It's common on old houses. Is that lead pipe on the drain lines? Believe it or not, I've never seen a lead pipe, since there aren't any in my area.
The drum trap should be removed, as it makes it very hard to snake a clogged drain line. The condensate drain should have an air gap, unless there is one farther upstream from its termination at the drum trap.
Rick Hurst's Avatar
Re: What is this?
Paul,
Thats an old drum trap and it should be removed and replaced.
Old 03-03-2008, 04:54 PM
Re: What is this?
It sure looked like lead, but I tapped on it with a screwdriver and it was hard? like steel. Weird.
Paul Kondzich
Old 03-03-2008, 05:51 PM
Re: What is this?
Quote:
Probably brass, lead encased.
Home inspection
vB.Sponsors
Ad Management by RedTyger
