Old 03-05-2008, 01:09 PM
Michael Thomas's Avatar
Michael Thomas Michael Thomas is online now
Seperate dishwasher drain
Is there an acceptable method of separately plumbing the drain of a residential dishwasher so that the entire arrangement is below counter-top level, for example to avoid the requirement for an air-gap at the counter-top?
Old 03-05-2008, 02:00 PM
Scott Patterson's Avatar
Re: Seperate dishwasher drain
Quote:
I guess it would all depend on the requirements for your area. In my area it is acceptable to loop the DW discharge line up under the sink "high loop" and then connect to the port on the disposal or sink drain line.
I have never seen a DW that did not drain into a sink line or disposal.
Scott Patterson
Old 03-05-2008, 03:52 PM
Aaron Miller Aaron Miller is offline
Senior Member
Scott's idea works unless, of course, the manufacturer requires the air gap.
Aaron
Old 03-05-2008, 04:13 PM
Nick Ostrowski Nick Ostrowski is offline
Then you should come to my house Scott. Our DW drains directly into the kitchen sink branch drain line in the basement area below. It's been that way since we've lived here (11+ years) and I've never felt inclined to change it, even though the drain line hook-up is admittedly incorrect.
Old 03-05-2008, 05:19 PM
Jim Robinson's Avatar
Jim Robinson Jim Robinson is offline
On some of the older houses, I sometimes see a standpipe used for the dishwasher. It's similar to what you would see for a washing machine. Of course, the only time you can see it is when the dishwasher is removed, or if you can somehow see behind it. I didn't have any problem with it.
Mine drains underneath and ties into the drain line in the crawl space. Like Nick, I've lacked motivation to change it, but someday I just might.
  #6 (permalink)
Old 03-05-2008, 05:55 PM
I did change the water supply line to the DW from cold to the hot supply (yes, the water supply line to our DW was the cold line). We had some real Einsteins that lived here before us.
Home inspection
Similar Threads
Seperate service to outbuilding serves circuits in main building with own service ... Michael Thomas Electrical Systems: Home Inspection and Commercial Inspection 3 02-17-2008 07:44 AM
Dishwasher Inspection Rick Hurst Built-In Appliances and Systems: Home Inspection and Commercial Inspection 22 06-29-2007 04:14 AM
Dishwasher drain line connection Jeff Eastman Plumbing System: Home Inspection and Commercial Inspection 4 06-02-2007 02:02 PM
Dishwasher David Banks Plumbing System: Home Inspection and Commercial Inspection 3 05-21-2007 07:51 PM
GE dishwasher recall John Arnold Built-In Appliances and Systems: Home Inspection and Commercial Inspection 2 05-16-2007 04:55 PM
vB.Sponsors
Ad Management by RedTyger
