Old 04-20-2007, 08:04 PM
wayne soper's Avatar
Propane tank location
Anyone know of the measurement needed from a propane tank to a road. I would say this one is too close but a # would be good to know. BOOM! Thats the road edge right in front of the tank. 250 year old home right on the corner of kaboom rd and skyrocket ln.
Old 04-20-2007, 10:34 PM
Re: Propane tank location
It's got to be 'within' the property lines, but other than that ... protecting it from vehicle damage would be ... er ... should be ... a *no brainer*, but I see someone had a lapse and created an 'Oops.' situation.
Good catch.
Old 04-21-2007, 04:30 AM
Thanks Jerry, When they put the house there they were only thinking of how to get from the horse to the house without touching the ground I guess.
Old 04-22-2007, 06:14 AM
BARRY ADAIR's Avatar
BARRY ADAIR BARRY ADAIR is offline
This what your looking for?
Residential-Commercial-Construction-EIFS-Infrared Thermography
Old 04-22-2007, 07:37 AM
Bob Harper's Avatar
Bob Harper Bob Harper is online now
NFPA 58, section 3.2.4.2-- "LP Gas containers or systems of which they are a part shall be protected from damage from vehicles."
Also, ASME containers must be at least 10 ft. from the property line except if >500 gal. w.c., they must be 25 ft. Buried ASME tanks Min. 10 ft. from lot lines.
No setbacks listed for DOT cylinders. However, you still must meet the clearance to windows etc. A tank at the roadside would have a 0 clearance to a source of ignition (cigarette), and thus not allowed. Also, the place where filled must not put the operator in danger. What about the ground? Is it sloped to shed gas or allow collection? That retaining wall will tend to hold gas against the base of the tank, which is a no-no. The base of the tank must be sloped or not have anything that would tend to allow gas to accumulate such as bushes, raised beds, etc. This LP company was nuts to install a tank here.
For your reports, I recommend you look in the tank and determine whether DOT cylinder or ASME container and the water capacity, which are needed to determine such clearances.
Similar Threads
Light switch location Jeff Eastman Electrical Systems: Home Inspection and Commercial Inspection 8 04-19-2007 12:57 PM
Propane regulator clearance Jim Luttrall Plumbing System: Home Inspection and Commercial Inspection 13 04-16-2007 08:30 AM
Water Heater Location Jeff Eastman Plumbing System: Home Inspection and Commercial Inspection 2 04-14-2007 10:52 PM
vB.Sponsors
Ad Management by RedTyger
