Re: Orphaned Water Heater Flue Requirements
The flue can be up to 7x the size of the smallest appliance. However, it will perform like a dog. It should be re-vented using B-vent installed to the listed instructions. If it vents into a chimney, it should be relined sized to the WH. It isn't up to the H.I. to specify the liner size, only it needs to be sized to fit that appliance and let the pros size it, whether B-vent or liner.
Single walled vent connector not allowed in unconditioned spaces or as chimney liner. Listed liner only.
HTH,
Bob
