Old 04-27-2007, 09:36 PM
Rick Hurst's Avatar
WAGS Valve?
Does anyone onboard have one of these on your personal water heater and have any comments about them?
I have (2) 75 gal. gas water heaters just sitting in the attic which I know one day will leak and cause problems. Only 2 yrs. old now, but we know that doesn't mean nothing.
Myself I see way too many of them leaking and am considering the installation of the WAGS valve to maybe have a bit more piece of mind.
Any idea on cost of them?
Below is a couple pictures I took a few weeks ago. If you notice in one picture, they have placed some foam type strips in front of the emergency drain pan openings. I assume this is to allow the water to back up somewhat in the pan for the WAGS valve to be able to be activated.
Any thoughts? Thanks as always.
Old 04-28-2007, 10:41 AM
Richard Stanley Richard Stanley is offline
Re: WAGS Valve?
What is WAGS? What is its purpose?
Old 04-28-2007, 11:12 AM
Joshua Hardesty Joshua Hardesty is offline
Re: WAGS Valve?
WAGS = Water And Gas Shutoff. In the event of a waterheater leak, the device, appropriately enough, shuts off the water and gas, to help prevent extensive damage. I've never installed one myself but my supplyhouse stocks them. Doesn't sound like a bad idea.
Old 04-28-2007, 12:00 PM
Re: WAGS Valve?
ABC Electrical Services - Water And Gas Safety Shut-Off Valve
Old 04-28-2007, 01:01 PM
Thom Walker's Avatar
Re: WAGS Valve?
Thanks for the ABC link. This product looks like it might be better than the others intended for the same purpose. That is, it appears less complicated, more localized, and not dependent upon any other utility.
Some others are:
http://www.watercop.com
http://www.thewateralarm.com
- Paul Fix
  #6 (permalink)
Old 04-28-2007, 01:20 PM
Re: WAGS Valve?
This might be just the ticket for older installations on slab foundations that don't have a drain line for the pan.
Mr. Inspector.net, Inc.
Allen, Texas 75002
  #7 (permalink)
Old 04-28-2007, 01:33 PM
Re: WAGS Valve?
I've been surprised by the numbers of plumbers I've talked to who aren't familiar with any of the systems. If you've ever seen the results of one seriously leaking in an attic, you'll quickly become a believer.
Some advantages of other systems are that the sensors can be placed anywhere and if water is detected, the entire supply is shut down. It would have been really handy the day I lost my balance and broke off the shut off valve at the toilet.
- Paul Fix
  #8 (permalink)
Old 04-28-2007, 05:10 PM
Michael Thomas's Avatar
Michael Thomas Michael Thomas is online now
Re: WAGS Valve?
Electronic WH and Whole-House shut-offs:
Automatic Water Heater Shut Off Valve
DynaQuip Controls - WaterCop Automatic Water Shut-off Systems
Similar Threads
Water heater valve Gregg Austensen Plumbing System: Home Inspection and Commercial Inspection 9 04-24-2007 09:06 PM
Air Admitance Valve in Manufactured Home Terre G Plumbing System: Home Inspection and Commercial Inspection 12 04-11-2007 07:51 AM
vB.Sponsors
Ad Management by RedTyger
