You are currently viewing InspectionNews as a guest which gives you limited access to view most discussions but not pictures. There are over 4,500 inspectors who have already joined. By joining InspectionNews you will be able to see the pictures, have access to post topics, communicate privately with other members, respond to polls, upload content and access many other special features. Registration is fast and simple so please, join InspectionNews today!
Old 05-08-2008, 12:09 PM
Kevin Rutledge Kevin Rutledge is offline
a couple of questions from the new home inspector
how do you fix water hammer? is it just in the venting? and the second question, do you have to have a gas shut off in the house??
thanks for any input.
Home inspection
Old 05-08-2008, 12:39 PM
Jon Randolph Jon Randolph is offline
Re: a couple of questions from the new home inspector
If you have water hammer, you usually have good water flow, which is a good thing. To prevent water hammer in an existing home, you can decrease the flow rate (not desireable) or install one or more dampeners. Dampeners can be bought, but you can just as easily make one. It is nothing but a piece of pipe capped on the end and installed vertically (with the capped end up) on the water pipes. Air will be trapped in this dampener and will "absorb" the shock created when the water flow is abbruplty stopped.
Water, like all fluids, is not compressible. You can put it under pressure, but can not compress it. When a valve is closed at the end of a run of plumbing the water in the pipe thinks that it is still going to be moving and continues to try to flow in that direction. The higher the water flow, the faster the water wants to continue moving. Since it is not compressible, it shakes the pipes as the molecules run into each other at the end of the run. This can damage the piping over time. Adding dampeners (filled with air that is compressible) gives the water somewhere to go and softens the blow at the end of the line.
Integrity Inspection Service, LLC
www.irsindy.com
(317) 345-1828
Old 05-08-2008, 12:42 PM
Welcome to the board, by the way.
www.irsindy.com
(317) 345-1828
Old 05-08-2008, 12:56 PM
David Banks David Banks is offline
Water Hammer | Builders Websource®
There should be a main shutoff at the meter it does not have to be in the house. Also each appliance should have a shutoff. If I remember correctly the exception is a Range.
Dave
Old 05-08-2008, 01:25 PM
Billy Stephens's Avatar
Billy Stephens Billy Stephens is offline
Kevin,
Check the fixture shut off where the sounds of water hammering is coming from to make sure it is opened all the way.
It Might have Choked Artie But it ain't gone'a choke Me!
Billy J. Stephens HI Service
  #6 (permalink)
Old 05-08-2008, 01:30 PM
John Arnold John Arnold is offline
Quote:
Originally Posted by David Banks View Post
...Also each appliance should have a shutoff. If I remember correctly the exception is a Range.
David - Are you thinking of sediment traps, maybe? I see no exception for ranges in the IRC.
  #7 (permalink)
Old 05-08-2008, 02:08 PM
Quote:
No I was not thinking sediment traps but I may be wrong. I can not find it anywhere but I thought I read it somewhere. Then again I am in Allergy hell right now.
Dave
  #8 (permalink)
Old 05-08-2008, 04:12 PM
There may be several problems going on at the same time.
There may be a anti-water hammer chamber already installed, and, if the old fashioned type, and if it worked for many years, it may have become waterlogged. Without air in it to compress, it is no longer effective. Those can usually be 'repaired' by simply draining the supply system of water and letting the water drain down out of the anti-water hammer chamber.
There may be loose piping (how many times do we find piping properly secured at the proper maximum spacing intervals?). If this is the case, then tracing down the loose pipe, and the loose section of that pipe, cutting the wall open, securing the pipe, then repairing everything back so it looks nice.
If this problem has always been there, then it may be a combination of no, or insufficient, anti-water hammer chambers and loose piping.
Adding additional anti-water hammer chambers may soften the pressure blows enough to compensate for loose piping, allowing the water hammer to stop.
Construction / Litigation Consultant www.ConstructionLitigationConsultants.com
  #9 (permalink)
Old 05-08-2008, 04:33 PM
...I am in Allergy hell right now.
I am in allergy purgatory. Claritin is useless. Zyrtec keeps me out of hell.
Our vehicles are covered in yellow pollen every morning.
  #10 (permalink)
Old 05-08-2008, 07:04 PM
Neither does me much good (not noticeable anyway). Which is why I still get allergy shots (one in each arm) every couple of weeks.
  #11 (permalink)
Old 05-09-2008, 06:25 AM
Richard Stanley Richard Stanley is offline
I have heard that water hammer could also be caused by under sized pipes. Is there any truth to that?
  #12 (permalink)
Old 05-09-2008, 06:35 AM
Quote:
This from the link I posted earlier.
Improperly sized supply lines for given peak water flow velocity;
Excessive system water pressure and lack of pressure-reducing apparatus;
Inadequate strapping or securing of plumbing to structure;
Excessively long straight runs with no bends;
Lack of expansion tank or other dampening system, such as water hammer arresters;
Dave
  #13 (permalink)
Old 05-09-2008, 07:51 AM
He didn't specify domestic hot water or heating water/steam. David's post is a good start since it makes it clear that there are multiple potential causes. It's like asking the mechanic what's wrong with my car when it won't start.
847/736-9975
Markus Keller
  #14 (permalink)
Old 05-09-2008, 09:11 PM
Patrick Martinez Patrick Martinez is offline
Hey Fellas,
the question on the water hammer is likely from one or more of the following, DW, ice maker or AW. Each can have an arrestor installed at the connection or inline and help to alleviate the problem.
  #15 (permalink)
Old 05-09-2008, 09:28 PM
thanks to everyone!! it is happening in a wall, best i can gather, when the downstairs shower is turned off.
  #16 (permalink)
Old 05-10-2008, 09:28 AM
Hate to say it but it sounds like the plumber didn't install any strapping / brackets. Bummer, but likely the fix, if accessible is to block the piping at the closest area to pull it to a wall and hopefully secure it. Otherwise "I'm Going In"....to the wall of of course....
Good luck to the new owners...
Pat
  #17 (permalink)
Old 05-10-2008, 09:30 AM
On another note, as to the expansion tank as a possible solution, that unfortunately will do nothing for the problem. Expansion tanks are only designed to help with closed loop systems on the cold side of the WH.
  #18 (permalink)
Old 05-10-2008, 05:23 PM
Joshua Hardesty Joshua Hardesty is offline
Pat
I've bored a 1/4" hole in the wall near the shaking pipes before and pumped a can or two of that expanding foam stuff inside there. I know, I know, it's a definate bubba, but it's far less intrusive than putting a hole in the wall.
  #19 (permalink)
Old 05-10-2008, 06:08 PM
Quote:
Joshua,
Copper piping or CPVC?
CPVC has a LOT of compatibility issues with many products, even many common caulks (which are, of course, used to 'caulk around the pipes').
Good - Americas - FGG/BM/CZ™ System Compatible Program
Not good - FGG/BM/CZ™ System Compatible Program
Some good / some not good - FGG/BM/CZ™ System Compatible Program
  #20 (permalink)
Old 05-10-2008, 09:03 PM
Joshua, I think I'd put the whole in the drywall set some brackets / tube talons etc and be done with it. The drywall is an easy fix and can make it look like you were never there.
Jerry has a great point on the compatibility issues.
  #21 (permalink)
Old 05-11-2008, 09:30 PM
Copper. I actually see very, very few homes done in CPVC. Mostly condos and apartments.
