You are currently viewing InspectionNews as a guest which gives you limited access to view most discussions but not pictures. There are over 4,500 inspectors who have already joined. By joining InspectionNews you will be able to see the pictures, have access to post topics, communicate privately with other members, respond to polls, upload content and access many other special features. Registration is fast and simple so please, join InspectionNews today!
Old 05-12-2008, 07:18 PM
Don Sweet Don Sweet is offline
Gurgle...gurgle
Hey guys, what causes a sink to gurgle when no apparent water is running anywhere in the house?
Driving everyone crazy!
Thanks,
Don
Old 05-12-2008, 07:35 PM
Randy Clayton Randy Clayton is offline
Re: Gurgle...gurgle
Don that was just discussed on the other post its proberly the ac drain
Old 05-12-2008, 07:59 PM
Gunnar Alquist's Avatar
Re: Gurgle...gurgle
Don,
My mother's house is located near the coast and she gets some really high winds when the storm come in across the pacific. The air flowing across the roof causes the pressure to drop rapidly in relation to the pressure in the house causing the water level in the toilet bowls to drop and the sinks to gurgle.
Does this happen during high winds? If not, then ignore my post.
It IS as bad as you think, and they ARE out to get you.
Old 05-12-2008, 08:28 PM
Re: Gurgle...gurgle
Unusual Air and Noise from Bath Sink - AC primary drain
This is the other thread referred to earlier.
The thought being the drain line on the A/C is not trapped and vented properly and is forcing air into or out of the condensate line under pressure of the blower.
Gunter's thought seems to be similar except with the outdoor wind pressure difference causing air to gurgle past the plumbing trap(s) only during high wind events.
Other thoughts, could be a blocked vent that lets a trap get sucked nearly dry... try tracking the noise to the particular trap and isolating the times that it happens (i.e. only when the wind blows out of the south over 10mph, anytime the a/c runs, etc.)
90% of fixing a problems is isolating the symptoms so that it can be reproduced or at least explained to the plumber, tech in enough detail for them to have a clue about what is going on.
Mr. Inspector.net, Inc.
Allen, Texas 75002
Old 05-13-2008, 06:12 AM
Re: Gurgle...gurgle
Thanks for the notes y'all.
Weather was warm and kinda balmy as I recall...not windy. The AC drain set-up could be the culprit.
Thanks. Don
Home inspection
vB.Sponsors
Ad Management by RedTyger
