Old 05-13-2008, 06:56 PM
Jerome W. Young Jerome W. Young is offline
a/c condensate terminating at sink drain
I am not even sure that this is a condensate line but i dont know what else it could be. The air handler is about 15 ft away and it is in a condo? Anyway i dont know what to say about this one
Old 05-13-2008, 07:08 PM
Rick Hurst's Avatar
Re: a/c condensate terminating at sink drain
Jerome,
The drainline in question is probably the primary condensate. It should not be vented to a sink. Although typical to see, it is wrong.
Old 05-13-2008, 08:35 PM
fritzkelly fritzkelly is offline
You should probably mention the broken dishwasher drain line, unless I am seeing that wrong.
OK, I think there is an elbow there, its hard to see.
The AHJ here allows condensate drain connection to a drain if there is a check valve, I don't know if thats OK other places.
Old 05-13-2008, 09:26 PM
Rick Hurst's Avatar
Fritz,
I learn years ago not to attempt to determine or what is acceptable by every AHJ in our area. He77, you'll get 2 different opinions from the inspectors within the same city.
Old 05-14-2008, 07:09 AM
Bruce Thomas's Avatar
Bruce Thomas Bruce Thomas is offline
It's been my experience that there should be a 4" air gap between the sewer drain and the condensate drain. That prevents bacteria from working it's way up the line and into the air handler. When I see these I call them (if I'm sure it's the condensate drain).
I've had sellers, agents and even some old time HVAC techs (that's the way we have always done it) go off on me about it but that's the price of fame.
Bruce
Make it a great day!
http://www.a-ztech.us
  #6 (permalink)
Old 05-14-2008, 07:22 AM
Brent Crouse Brent Crouse is offline
Bruce, when you say "4 inch air gap", are you talking about (in this picture) 4" from the sink's p-trap to where the point where the condensate line connects to the sink's drain?
  #7 (permalink)
Old 05-14-2008, 07:35 AM
Richard Rushing's Avatar
UPC says it's okey dokey.... (C)
Since the Uniform Plumbing Code says it's ok, the folks at Code Check recoginize it as o.k. as well.
Good'nuff for me.
Richard
Richard Rushing, HCRI
Duncanville, Tx.
  #8 (permalink)
Old 05-14-2008, 07:37 AM
Those hose-clamps look like they came off an old 58 chevy...
Rich
Duncanville, Tx.
  #9 (permalink)
Old 05-14-2008, 07:46 AM
- Is that lamp cord plugged into a regular outlet running to feed the disposal unit?
- If that's the DW drain hose running to the disposal just sort of laying there then it doesn't look like it has the trap loop going for it.
- Might consider mentioning that they may get some smell out of the kitchen sink with the condensate hook-up like that. Especially if there's no trap on the pvc coming through wall or if the unit doesn't run for a while.
Just wondering.
Markus Keller
  #10 (permalink)
Old 05-14-2008, 10:39 AM
brian schmitt brian schmitt is online now
you might make a comment about 2 traps on one trap arm,an obvious violation?
  #11 (permalink)
Old 05-14-2008, 12:16 PM
I'm not a code guy, I don't even use the "C" word. The code is only a place to start in my mind.
When I said 4" air gap I was talking about a drop in open air from the condensate drain into the sewer drain. That way bacteria from the sewer can't find it's way into the air handler from the sewer.
I think it's a good idea but then again there is that "C" thing. The politically motivated good place to start.
Bruce
  #12 (permalink)
Old 05-14-2008, 02:37 PM
Good'nuff for me.
Richard
Richard,
"Good'nuff for me."
Ummm ... are you under the UPC? Or the ICC codes?
And ... do you have the wording in the UPC which allows it?
  #13 (permalink)
Old 05-14-2008, 03:19 PM
Jeffrey L. Mathis Jeffrey L. Mathis is offline
In my world, it is against the law to dump a condensate drain or any sump pump drain into the municipal sewer system. A utility co. manager explained to me that sewer systems are almost always operating at capacity and they'd just as soon not treat water just for the sport of it.
The city has apprised builders of it and demanded that they cease.\
JLMathis
  #14 (permalink)
Old 05-14-2008, 03:57 PM
Jeffrey, where is your part of the world?
Around here, NOT putting condensate in the sewer would be asking for trouble with foundations.
Mr. Inspector.net, Inc.
Allen, Texas 75002
  #15 (permalink)
Old 05-16-2008, 03:07 PM
jim:
I'm in Greenville, N.C.
I accidently ratted out the practice.
I inspected a crawl space with a sump pump and casually called one of my better friends who manages a division of Greenville Utilities. He asked up the line and I had an idea that it was against the policy of the utility co to dump anything into the sewer other than house waste. He confirmed that as well as that condensate was also improper and, in fact, statutorily illegal.
Why would any condenste pose a foundation issue if it is properly lead away from the house by proper grading?
Around here, we're just a smidge above sea level as it is, but decent grading will disburse that amount of water satisfactorily.
JLMathis
  #16 (permalink)
Old 05-16-2008, 04:26 PM
Quote:
Why would any condensate pose a foundation issue if it is properly lead away from the house by proper grading?
Expansive clay soils. During the 6 or 7 months of not stop A/C use with no rain for months sets the stage then add in a 5' side yard dumping condensate on one side of the house and your in trouble. They used to put in a dry well of sorts a foot or so away from the foundation and dump the condensate there, but that is a rarity now.
Allen, Texas 75002
  #17 (permalink)
Old 05-16-2008, 08:27 PM
Randy Clayton Randy Clayton is offline
I would have to agree with Jim you do not want to dump the condensate to the exterior but to the dwv. So why not the sink drian as long as it is before and above the trap???
  #18 (permalink)
Old 05-16-2008, 08:41 PM
Quote:
Where you ...
wash your hands
wash your face
brush your teeth
prepare your food
"So why not ... "
Just something little called ... bacteria ... and ... sanitation ...
  #19 (permalink)
Old 05-16-2008, 09:00 PM
Agree, but have you ever opend a "p" trap with or without an ac drain you tell me the differance!! None from what I can see
  #20 (permalink)
Old 05-16-2008, 09:04 PM
Don't know what different types of bacteria are in the two, but I suspect they are not the same.
Seems as though that must make a big difference, 'cause the code (being "minimum") recognizes it, and if "minimum" recognizes it, why would one want to challenge it and go against even "minimum"?
Beats the heck out of me why some so insist, though.
  #21 (permalink)
Old 05-16-2008, 09:13 PM
Ok, I must be behind I'm unaware of any code dissallowing this type of termination point???
