You are currently viewing InspectionNews as a guest which gives you limited access to view most discussions but not pictures. There are over 4,500 inspectors who have already joined. By joining InspectionNews you will be able to see the pictures, have access to post topics, communicate privately with other members, respond to polls, upload content and access many other special features. Registration is fast and simple so please, join InspectionNews today!
Old 05-16-2008, 07:49 PM
Trent Tarter Trent Tarter is offline
S-trap?
This does not look right. Is this considered an S-trap?
Old 05-16-2008, 08:00 PM
Re: S-trap?
Nope, not an 'S' trap, but ...
It sure would make a good ride at Busch Gardens in Tampa.
What is facing the camera off to the right? A clean out?
Construction / Litigation Consultant www.ConstructionLitigationConsultants.com
Old 05-16-2008, 08:12 PM
Re: S-trap?
Thanks Jerry,
I didn't think it was an s-trap, but it just didn't look right. I am not sure what that thing is to the right. This home was built in 1900 it could be anything.
Old 05-16-2008, 08:31 PM
Re: S-trap?
Quote:
Trent,
Built in 1900 has nothing to do with ABS pipe like that.
To make sure you are talking about the same thing I am asking about:
The white PVC tailpiece goes down to the trap, which curls up into the wall bend, which connects into the ABS fixture drain, which curls around toward the read entering into what looks like a wye fitting, toward (hidden from view) a fitting which turns back upward, then an ABS 45 sweep back behind the cabinet.
The part I am asking about is the wye ... what is almost facing the camera on the right? My guess is a clean out fitting.
Then, in the back wall of the cabinet, there is an ABS clean out.
Some how, it looks to me, that horizontal piece going off to the left must turn back to the right and ... wait, I understand now ...
That wye goes straight back into the back of the cabinet, with another wye (or some other fitting) turned up at a 45 degree angle, which comes from (instead of goes to) something else.
That would leave the piece facing the camera as a clean out.
Or so I think.
Of course, though, I'm guessing that the fitting past the wye is a sanitary tee (or, worse, a regular tee) and is turned up at a 45 degree angle - of course, though, a sanitary tee (much less a regular tee) is not allowed to be there for that change in direction.
Okay, so it's not the super duper loop-de-loop I first thought it was, but now I see more problems with it.
Old 05-17-2008, 05:35 AM
Jim Zborowski Jim Zborowski is offline
Re: S-trap?
After looking at it closer, it does look like an s-trap with 1/2 the s being turned on its side so it acts like a p trap, just with a bizzar twist. A p-s trap ????????
  #6 (permalink)
Old 05-17-2008, 05:41 AM
Vern Heiler Vern Heiler is offline
Re: S-trap?
Is there an approved cement for the joining of PVC and ABS? I think the horizontal piece going left is the vent. Everything would look normal if the vent was connected inside the wall and the trap could have pointed straight at the wall.
  #7 (permalink)
Old 05-17-2008, 11:59 AM
Michael Larson's Avatar
Michael Larson Michael Larson is offline
Re: S-trap?
Quote:
Yes,
See This
Your local AHJ may not approve this application and if they do, it is usually only for one transition such as joining new to old work.
A call to your local AHJ would be in order.
  #8 (permalink)
Old 05-17-2008, 05:08 PM
Re: S-trap?
Thanks Michael, it's been several years since I looked for that answer. The product was available but not approved at the time. Glad I don't see it very often.
Home inspection
Similar Threads
p-trap Jeff Eastman Plumbing System: Home Inspection and Commercial Inspection 11 09-17-2007 08:15 PM
Is This An 'S' Trap? Bruce Breedlove Plumbing System: Home Inspection and Commercial Inspection 6 08-03-2007 07:13 PM
Definition of a trap arm. Bob Mayer Plumbing System: Home Inspection and Commercial Inspection 1 07-15-2007 05:25 PM
p-trap John Stephenson Plumbing System: Home Inspection and Commercial Inspection 7 05-16-2007 04:28 PM
trap wayne soper Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 4 05-06-2007 12:11 PM
vB.Sponsors
Ad Management by RedTyger
