Old 05-19-2008, 06:45 PM
Vern Heiler's Avatar
Vern Heiler Vern Heiler is offline
Toilet Fill Tube Missing
I inspected a house today built in 2005. All of the toilets have the same type ball-cock in the tank. All of the toilets are missing the fill tube to the overflow. No water comes out of the tube connection at the ball-cock. I don't know if it came from mfg. this way or did the HO plug it?
We are in a draught here in the SE, but think this might be going a bit far. The toilet bowl does not fill after flushing, just a little left in the bottom. I did not give it the litmus test but think flush may be weak at best.
Is the toilet functioning as intended?
Vern
Old 05-19-2008, 07:40 PM
Re: Toilet Fill Tube Missing
Quote:
Vern,
"as intended"
No.
"is functioning properly"?
No.
Old 05-19-2008, 07:52 PM
Thanks Jerry, that was my original thought until I noticed no water from the tube fitting. Don't know how they are plugged. I'll let the plumber figure it out.
Old 06-06-2008, 03:54 PM
Tony Watson Tony Watson is offline
This is the way this w/c is designed to work, changing the fill valve will not improve the flush only waist water. The flush cycle is timed using the flapper.
Old 06-07-2008, 08:46 AM
Thanks Tony, I had a suspicion there was some design change. Do you have a web site or some reference I could go to?
  #6 (permalink)
Old 06-07-2008, 07:44 PM
It is the original equipment for that W/C. A local sales rep, or their web site shoud be a good source.
Home inspection
Similar Threads
Maximum fill for conductors in a panel board Wendell Swedberg Electrical Systems: Home Inspection and Commercial Inspection 3 04-30-2008 07:29 PM
no back fill wes owens Sub-Structure: Home Inspection and Commercial Inspection 4 03-26-2008 07:16 PM
Fill 'er up ! Nolan Kienitz Electrical Systems: Home Inspection and Commercial Inspection 9 03-06-2008 01:45 PM
Tube lights Ron Bishop Electrical Systems: Home Inspection and Commercial Inspection 7 12-31-2007 10:57 AM
That Big You Tube Ad Rick Hurst InspectionBlues: Home Inspectors & Commercial Inspectors 8 10-16-2007 05:46 PM
vB.Sponsors
Ad Management by RedTyger
