Old 04-30-2007, 09:19 AM
Upsized water heater vent pipe
Old 04-30-2007, 09:25 AM
Brian E Kelly Brian E Kelly is offline
Re: Upsized water heater vent pipe
That upsize is needed as you are putting two vents into on and the total loads of both will determine the size of the main vent. As I see it ini the picture the water heater vent is tied into the main vent with another system tied into the main vent. Everything in that picture looks good other than the pipe supports or lack of.
Well thats my 2 cents.
Brian Kelly
Kelly Home Inspections
Old 04-30-2007, 10:32 AM
Michael Thomas's Avatar
BTW, what was happening that caused them to caulk the wall-ceiling junction?
Similar Threads
Water heater Leak? K Robertson Plumbing System: Home Inspection and Commercial Inspection 5 04-30-2007 09:22 PM
gas water heater location wes owens Plumbing System: Home Inspection and Commercial Inspection 5 04-29-2007 09:52 AM
Water Heater Location Jeff Eastman Plumbing System: Home Inspection and Commercial Inspection 2 04-14-2007 09:52 PM
Water heater Question Jeff Eastman Plumbing System: Home Inspection and Commercial Inspection 2 04-12-2007 03:29 PM
ABS Flue Pipe on LP Water Heater Trey Humphreys Plumbing System: Home Inspection and Commercial Inspection 6 04-03-2007 01:11 PM
vB.Sponsors
Ad Management by RedTyger
