Old 04-30-2007, 06:23 PM
Roni Litmanovic Roni Litmanovic is offline
Acceptable under kitchen sink???
Doesn't look too good...water damage everywhere...
Home inspection
Old 04-30-2007, 06:40 PM
wayne soper's Avatar
Re: Acceptable under kitchen sink???
With GFCI protection OK! No Pro, no go!
Old 04-30-2007, 06:53 PM
That surface wire is not good.
Otherwise, being under the sink is not prohibited, nor does it require GFCI protection.
Now, under my kitchen sink, I have a two gang box with two duplex receptacle outlets in it, facing up - BUT - I have a two gang bubble type weather proof cover over it.
Old 04-30-2007, 07:17 PM
Michael Thomas's Avatar
I'd at least note that most things likely plugged in there (dishwasher, disposal) would require a grounded receptacle to accept the required grounded plug.
Old 04-30-2007, 08:34 PM
Quote:
That is a grounding-type receptacle.
  #6 (permalink)
Old 04-30-2007, 09:40 PM
Richard Rushing's Avatar
Yup.. I had to go back and re-look and say, whaaat?
No need of gfci protection. As previously stated, that exposed surface wire should be protected.
Rich
  #7 (permalink)
Old 05-01-2007, 06:53 AM
By the way, is that blue thingy (technical term) a water filter with the filter removed?
  #8 (permalink)
Old 05-01-2007, 11:00 AM
Sorry. Looked at that, got distracted, can back to post, *thought* I has seen an ungrounded outlet, and didn't look back to check...
Similar Threads
Plumbing under kitchen sink.... Roni Litmanovic Plumbing System: Home Inspection and Commercial Inspection 6 04-30-2007 10:29 PM
Kitchen vent Jeff Eastman Attic Areas: Home Inspection and Commercial Inspection 5 04-30-2007 06:42 PM
return over range in kitchen wes owens Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 14 04-27-2007 10:56 AM
Kitchen area GFCI Phillip Stojanik Electrical Systems: Home Inspection and Commercial Inspection 6 04-18-2007 11:44 PM
From the old board, Acceptable Repairs Tim Moreira Electrical Systems: Home Inspection and Commercial Inspection 1 04-02-2007 05:09 AM
vB.Sponsors
Ad Management by RedTyger
