04-30-2007, 05:23 PM
Acceptable under kitchen sink???
Doesn't look too good...water damage everywhere...
04-30-2007, 05:40 PM
Re: Acceptable under kitchen sink???
With GFCI protection OK! No Pro, no go!
04-30-2007, 05:53 PM
That surface wire is not good.
Otherwise, being under the sink is not prohibited, nor does it require GFCI protection.
Now, under my kitchen sink, I have a two gang box with two duplex receptacle outlets in it, facing up - BUT - I have a two gang bubble type weather proof cover over it.
04-30-2007, 06:17 PM
I'd at least note that most things likely plugged in there (dishwasher, disposal) would require a grounded receptacle to accept the required grounded plug.
04-30-2007, 07:34 PM
That is a grounding-type receptacle.
04-30-2007, 08:40 PM
Yup.. I had to go back and re-look and say, whaaat?
No need of gfci protection. As previously stated, that exposed surface wire should be protected.
Rich
05-01-2007, 05:53 AM
By the way, is that blue thingy (technical term) a water filter with the filter removed?
05-01-2007, 10:00 AM
Sorry. Looked at that, got distracted, can back to post, *thought* I has seen an ungrounded outlet, and didn't look back to check...
| Thread Tools |
Search this Thread |
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
| Plumbing under kitchen sink.... |
Roni Litmanovic |
6 |
04-30-2007 09:29 PM |
| Kitchen vent |
Jeff Eastman |
Attic Areas: Home Inspection and Commercial Inspection |
5 |
04-30-2007 05:42 PM |
| return over range in kitchen |
wes owens |
14 |
04-27-2007 09:56 AM |
| Kitchen area GFCI |
Phillip Stojanik |
6 |
04-18-2007 10:44 PM |
| From the old board, Acceptable Repairs |
Tim Moreira |
1 |
04-02-2007 04:09 AM |
