Old 05-31-2008, 02:43 PM
Tom Rees Tom Rees is offline
Black iron pipe
I ran into a main water supply pipe Friday that at visible area in crawlspace was black iron pipe generaly used for gas line. I wrote it up as improper material as it will rust easily. I am not sure if it ran all the way to meter, not visible. Any comments?
Old 05-31-2008, 05:26 PM
Jerry McCarthy's Avatar
Re: Black iron pipe
You did good Tom and makes one wonder if had been previously used for natural gas?
Construction Consultant
Old 05-31-2008, 05:29 PM
James Duffin James Duffin is offline
Re: Black iron pipe
How old was the house...just curious?
Old 05-31-2008, 07:11 PM
Re: Black iron pipe
House was 1935 but pipe is newer, switched over from coal furnace.
Old 05-31-2008, 07:34 PM
wayne soper's Avatar
Re: Black iron pipe
Any rust in the water yet? Good call. And the repair certainly worked in a pinch but life has it's rules and you usually get caught for cheating.
  #6 (permalink)
Old 05-31-2008, 07:50 PM
Re: Black iron pipe
What was the house distribution system plumbed with?
  #7 (permalink)
Old 06-01-2008, 04:49 PM
Re: Black iron pipe
James, House was recently repiped with copper however some galvanized was still seen but not in use.
  #8 (permalink)
Old 06-03-2008, 10:18 AM
Randy Aldering Randy Aldering is offline
Re: Black iron pipe
Black iron pipe isn't even NSF rated for potable water, is it? Good call. The things we see ...
Randy Aldering, RHI CHI
Housesmithe Home Inspection
www.housesmithe.com
  #9 (permalink)
Old 06-03-2008, 07:18 PM
Re: Black iron pipe
Quote:
Definitely not in Table P2904.5, Water Distribution Pipe as an allowed pipe, nor is it in Table P2904.4, Water Service Pipe as an allowed pipe.
  #10 (permalink)
Old 06-06-2008, 09:35 AM
Mike Schulz's Avatar
Mike Schulz Mike Schulz is online now
Re: Black iron pipe
Are you sure it is not the gas supply. Did you actually see where it entered into the home and was piped off of that?
Maybe someone surface painted it because of surface rust........
I doubt it runs to the meter. I think county would of picked up on that, don't you think.
Just wondering..........
Mike Schulz License 393
Affordable Home Inspections
www.houseinspections.com
  #11 (permalink)
Old 06-06-2008, 09:43 AM
Re: Black iron pipe
Mike, I think you have been listening to realtors too long.
Mr. Inspector.net, Inc.
Allen, Texas 75002
  #12 (permalink)
Old 06-06-2008, 10:09 AM
Re: Black iron pipe
The day I start listening to Realtors is the day I will get sued!
  #13 (permalink)
Old 06-06-2008, 10:35 AM
Bruce King Bruce King is offline
Re: Black iron pipe
Ductile iron pipe is used for water but I think it starts around 2 inch dia.
  #14 (permalink)
Old 06-06-2008, 11:49 AM
Re: Black iron pipe
Mike, It was the water supply line, no doubts-none. I am not sure how far it ran towards meter as it is underground and I could not see at meter.
Similar Threads
PVC to black pipe connections Jeff Beck Plumbing System: Home Inspection and Commercial Inspection 22 05-23-2008 07:42 PM
Is PB the only Black line? Reis Pearson Plumbing System: Home Inspection and Commercial Inspection 11 01-26-2008 08:47 PM
Vent Pipe contacting Gas Pipe Ken Amelin Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 10 01-22-2008 06:50 PM
Copper to cast iron drain Jeff Eastman Plumbing System: Home Inspection and Commercial Inspection 1 09-25-2007 06:04 PM
iron mushroom John Arnold Plumbing System: Home Inspection and Commercial Inspection 6 04-19-2007 04:56 PM
vB.Sponsors
Ad Management by RedTyger
