Old 06-03-2008, 02:13 PM
Richard Roshak Richard Roshak is offline
Vent pipe in attic
The owner ran this plumbing vent up, over and down, so that he could install pull down stairs. I don't think this is a problem, however I thought I would ask to be sure.
Rich
Home inspection
Old 06-03-2008, 02:32 PM
Jon Randolph Jon Randolph is offline
Re: Vent pipe in attic
By up, over and down I assume that you mean he created an upside down u (or an n) with the vent pipes. If so, this is wrong. It will trap rain water and condensate in the section that goes up and through the roof.
BTW....
I always write up those cheap pull down stairs as low quality and caution the client about relying on them to enter/exit the attic safely. I also list them as a breach of the fire separation between the home and garage if installed in the garage, unless provisions have been made to resist fire.
Integrity Inspection Service, LLC
www.irsindy.com
(317) 345-1828
Old 06-03-2008, 02:36 PM
It does not go through the roof and it terminates into a main vent.
Rich
Old 06-03-2008, 05:57 PM
Vent is still wrong, needs to slope and not trap condensation.
Mr. Inspector.net, Inc.
Allen, Texas 75002
Old 06-03-2008, 07:15 PM
A vent needs to "vent".
That's a large trap, that is not going to "vent" (at least not properly).
He would have been better off (and it would have been easier and cheaper - less pipe) to 'go around'. Sloping uphill as he went 'around'.
  #6 (permalink)
Old 06-03-2008, 07:28 PM
Brandon Whitmore Brandon Whitmore is offline
Like everyone else has said-- wrong. Everything must slope back toward the sewer line.
  #7 (permalink)
Old 06-03-2008, 07:33 PM
Lost my head today. 1/4" per foot back to the main drain/vent.
Rich
  #8 (permalink)
Old 06-04-2008, 05:08 AM
Quote:
Rich
That is the minimum for waste piping but as long as there is some slope in the vent piping, I wouldn't get excited. You don't have to worry about solids settling out in the vent, unless it is a wet vent in which case it becomes waste piping.
www.irsindy.com
(317) 345-1828
  #9 (permalink)
Old 06-06-2008, 04:41 AM
Tony Watson Tony Watson is offline
If both Horizontal pipes are slopped in the direction that they would drain, then this configuration will work. The pipe size though is another issue. The configuration as shown looks like an "island vent", without a sink draining into it.
  #10 (permalink)
Old 06-06-2008, 05:32 AM
Joshua Hardesty Joshua Hardesty is offline
Tony: I don't believe the photo shows two vents flowing away from eachother that tie in above where we can see adn then shoot out the roof. We're looking at what used to be one long horizontal vent running near the floor, that the homeowner jogged up out of his way so they could put in an access to the attic, so both horizontal pipes are sloped the same way.
  #11 (permalink)
Old 06-06-2008, 12:36 PM
Rich
If one side ties into a vent TEE and the other side is the upper section of a common or individual vent then both sides have to drain to a stack, with the right grade of course.
  #12 (permalink)
Old 06-06-2008, 01:29 PM
Quote:
Originally Posted by Tony Watson View Post
If The configuration as shown looks like an "island vent", without a sink draining into it.
Tony,
Think of it as a "high loop" instead of an "island vent".
The island vent is tied back down to the drain, creating a vent path.
That is a high loop, not tied back down to anything, creating a trap (inverted trap, which traps air).
Home inspection
Similar Threads
automatic vent in attic Jerome W. Young Plumbing System: Home Inspection and Commercial Inspection 4 04-20-2008 06:27 AM
attic furnace flex pipe and exhaust stack CHARLIE VAN FLEET Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 3 02-23-2008 09:01 AM
Vent Pipe contacting Gas Pipe Ken Amelin Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 10 01-22-2008 06:50 PM
Single wall pipe to b-vent vent question Brian E Kelly Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 5 12-19-2007 05:55 PM
Vent pipe wayne soper Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 4 07-01-2007 06:39 PM
vB.Sponsors
Ad Management by RedTyger
