Old 06-09-2008, 03:43 PM
John Arnold John Arnold is online now
missing crimp ring?
My excuse for what is probably a stupid question: I almost never see pex. Maybe once a year at most. I do very little new construction.
Anyway, my question is, isn't there supposed to be a crimp ring at the bottom of that red line?
Home inspection
Old 06-09-2008, 03:57 PM
David J. Smith David J. Smith is offline
Re: missing crimp ring?
No it is not missing because the crimp ring you see on the blue line is to connect the valve to the pipe, the red and blue pipes are held in place by the adapters to the copper pipes.
David
Old 06-09-2008, 04:06 PM
Dom D'Agostino Dom D'Agostino is offline
That's a Shark Bite (or similar) fitting, no crimp ring needed.
Read about it here:
Shark Bite info
Old 06-09-2008, 04:09 PM
Thanks guys. I appreciate it.
Old 06-09-2008, 04:37 PM
Jon Randolph Jon Randolph is offline
My brother-in-law (a licensed plumber) says that those shark bite fittings will put plumbers out of business. He wasn't serious of course, but they can be used to connect almost anything to almost everything else.
Regarding the pic, I would have liked to see more pex exposed between the valve and the sharkbite to ensure that the pex was inserted fully into the fitting, but if it is not leaking, nothing can really be said.
Integrity Inspection Service, LLC
www.irsindy.com
(317) 345-1828
Last edited by Jon Randolph : 06-09-2008 at 07:11 PM. Reason: spppppppelllllllllllliinnnnnng
  #6 (permalink)
Old 06-09-2008, 05:25 PM
Joshua Hardesty Joshua Hardesty is offline
As expensive as those things are... I think us plumbers will be okay for a while.
The fittings that frighen me are those cheap plastic fittings you find with the big compression joints. Any time I've seen them they've been leaking. Haven't yet had a problem with a sharkbite, but still I don't ever use them inside walls.
There's also another fitting, it's an angle stop, with a similar connection as a sharkbite. However, it's also got an integral supply line built into it. The thing is, instead of using the removal tool like you would with the sharkbite, with this fitting you twist it to the right 90* and it pops off. My first thoughts were, "Well, what if the supplyline is a bit too long, causing binding, which then pushes the valve to the right?"
Can't wait to see what happens if these get sold a lot.
Home inspection
Similar Threads
WHATS MISSING HERE??? CHARLIE VAN FLEET Roofing System: Home Inspection and Commercial Inspection 3 05-21-2008 10:21 PM
Something's missing Matt Fellman General Chit Chat: Home Inspectors & Commercial Inspectors 3 04-11-2008 11:21 PM
Missing Posts John Allingham Electrical Systems: Home Inspection and Commercial Inspection 4 01-05-2008 03:48 PM
What's Missing Here? PETER W BENNETT Building Envelope: Home Inspection and Commercial Inspection 32 09-13-2007 12:09 PM
Missing A/C Condensing Unit - Take 2 Bruce Breedlove Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 5 04-02-2007 12:54 PM
vB.Sponsors
Ad Management by RedTyger
