Old 07-03-2008, 05:57 PM
Rick Hurst's Avatar
CPVC ?
Do you call out CPVC on top of a gas water heater when it is close to the exhaust?
I always have called it out as being a risk for heat damage but all the plumbers around say its ok.
Any feedback.
Old 07-03-2008, 06:03 PM
Nick Ostrowski Nick Ostrowski is offline
Re: CPVC ?
I would still call it Rick. If the plumbers want to take ownership of that flood-to-be, I say let em' have at it. If I remember correctly, CPVC is only stable for temperatures up to 180 degrees and that's from water in the pipes. I could see the pipe melting if you get a water heater that has a backdrafting issue or even if it is firing for an extended period of time due to usage of a lot of hot water (bathing, washing machine running at same time).
Old 07-03-2008, 08:32 PM
Re: CPVC ?
Quote:
Rick,
It is required to be 6" from the drafthood, 6" from single wall vent, and 1" from Type B gas vent.
Let the plumbers say it is okay an do it, you just give them the code section/manufacturers' installation instructions which tells them *not* to do it.
Old 07-03-2008, 08:39 PM
Rick Hurst's Avatar
Re: CPVC ?
This is the one in question.
Old 07-03-2008, 08:42 PM
Re: CPVC ?
Rick,
From the draft hood it requires 6" clearance to *all* combustible material: the CPVC, the foam insulation, etc.
That's not even addressing the effect of the heat on the CPVC, just that the CPVC is 'combustible'.
Home inspection
Similar Threads
CPVC fitting labeled "cold water only" Greg Jenkins Plumbing System: Home Inspection and Commercial Inspection 39 06-09-2008 12:08 PM
PVC, CPVC, polybutelyne...what is it? Ron Bishop Plumbing System: Home Inspection and Commercial Inspection 6 12-02-2007 09:14 AM
discolored cpvc on water heater wes owens Plumbing System: Home Inspection and Commercial Inspection 10 06-06-2007 05:32 PM
Flow guard CPVC David Banks Plumbing System: Home Inspection and Commercial Inspection 8 04-24-2007 08:15 AM
vB.Sponsors
Ad Management by RedTyger
