Old 07-07-2008, 05:26 PM
Jerry McCarthy's Avatar
Plumbing Code
Who has a code reference on this?
Construction Consultant
Old 07-07-2008, 06:02 PM
Gunnar Alquist's Avatar
Re: Plumbing Code
Mmmm... cozy.
The apostrophe troll.
Old 07-07-2008, 06:08 PM
Rick Cantrell Rick Cantrell is offline
Re: Plumbing Code
Hey, that looks like a good idea. When I get up in the middle of the night, I'm bound to hit one.
Rick Cantrell
Old 07-07-2008, 06:11 PM
Re: Plumbing Code
Quote:
WC Jerry,
These for starters.
From the IPC.
- 310.5 Urinal partitions. Each urinal utilized by the public or employees shall occupy a separate area with walls or partitions to provide privacy. The construction of such walls or partitions shall incorporate waterproof, smooth, readily cleanable and nonabsorbent finish surfaces. The walls or partitions shall begin at a height not more than 12 inches (305 mm) from and extend not less than 60 inches (1524 mm) above the finished floor surface. The walls or partitions shall extend from the wall surface at each side of the urinal a minimum of 18 inches (457 mm) or to a point not less than 6 inches (152 mm) beyond the outermost front lip of the urinal measured from the finished back wall surface, whichever is greater.
- - Exceptions:
- - - 1. Urinal partitions shall not be required in a single occupant or unisex toilet room with a lockable door.
- - - 2. Toilet rooms located in day care and child care facilities and containing two or more urinals shall be permitted to have one urinal without partitions.
- 405.2 Access for cleaning. Plumbing fixtures shall be installed so as to afford easy access for cleaning both the fixture and the area around the fixture.
- 405.3 Setting. Fixtures shall be set level and in proper alignment with reference to adjacent walls.
- - 405.3.1 Water closets, urinals, lavatories and bidets. A water closet, urinal, lavatory or bidet shall not be set closer than 15 inches (381 mm) from its center to any side wall, partition, vanity or other obstruction, or closer than 30 inches (762 mm) center-to-center between adjacent fixtures. There shall be at least a 21-inch (533 mm)clearance in front of the water closet, urinal, lavatory or bidet to any wall, fixture or door.Water closet compartments shall not be less than 30 inches (762 mm) wide and 60 inches (1524 mm) deep (see Figure 405.3.1).
Old 07-07-2008, 06:32 PM
Re: Plumbing Code
Not that I would no in the slightest but it seems like it would be just fine for a local gay bar. I don't think a code would apply there (maybe legal vice code)
Ted Menelly
"Castle"
Home Inspection Services
  #6 (permalink)
Old 07-07-2008, 08:56 PM
Re: Plumbing Code
Quote:
Ted,
Did you read the code sections I posted? Both code sections apply, and that does not conform to either code section.
  #7 (permalink)
Old 07-07-2008, 09:04 PM
Re: Plumbing Code
I was just being a bit of a smart arse.
Yes I read the codes and they do apply.
I just thought the two urinals in the corner of a mens room were quite hilarious and was just thinking where code might not matter to some folks
Ted Menelly
"Castle"
  #8 (permalink)
Old 07-07-2008, 09:07 PM
Rick Hurst's Avatar
Re: Plumbing Code
Maybe that place of business has some Siamese twins who work there.
Hey, its possible.
  #9 (permalink)
Old 07-07-2008, 09:47 PM
Re: Plumbing Code
Ted,
My bad. Whoooosh ... right over my head.
I've seen a photo where there were two toilets facing each other in the same stall - here in the states too.
Another ... Oops!
I guess that may have been intended to allow to workers to discuss the project at the same time they were 'taking care of business'?
  #10 (permalink)
Old 07-08-2008, 08:50 AM
Re: Plumbing Code
Apparently you guys have never heard of Bing & Ying, the famous Siamese twins? This set up was custom made especially for them.
Similar Threads
A matter of code Joshua Hardesty Plumbing System: Home Inspection and Commercial Inspection 7 02-09-2008 01:41 PM
Code Certification Charles Cole Introductions By New Members 13 09-20-2007 09:28 AM
Plumbing vent Jeff Eastman Plumbing System: Home Inspection and Commercial Inspection 1 06-27-2007 04:53 PM
Code Help Matt Hawley Roofing System: Home Inspection and Commercial Inspection 9 06-26-2007 08:54 PM
Plumbing line John Stephenson Plumbing System: Home Inspection and Commercial Inspection 4 06-10-2007 11:34 AM
vB.Sponsors
Ad Management by RedTyger
