Old 07-15-2008, 06:32 PM
mathew stouffer mathew stouffer is offline
Expansion Tanks On Cold Water Lines
I thought water heater expansion tanks had to be on the Hot water line. I found two installations today with the tank on the cold water line. The first photo, the tank was connected to the main water line for the home. Any thoughts?
Mat
Home inspection
Old 07-15-2008, 06:35 PM
Gunnar Alquist's Avatar
Re: Expansion Tanks On Cold Water Lines
I can't imagine that it would really matter. I guess you could refer to the manufacturer's installation instructions.
What is the circumference of a moose?
Old 07-15-2008, 06:39 PM
Billy Stephens's Avatar
Billy Stephens Billy Stephens is offline
Quote:
Originally Posted by mathew stouffer View Post
-- installations today with the tank on the cold water line.
Any thoughts?
Mat
Both Installation manuals I have show expansion tank on inlet side.
Watt's and attachment
Billy J. Stephens HI Service
Old 07-15-2008, 06:53 PM
David Banks David Banks is offline
This was addressed recently.
Expansion Tank on Hot side
Dave
Old 07-15-2008, 07:58 PM
They say cold water side, a few may allow on hot water side, however, they also state shorter life if on the hot side, however ...
They should not be mounted with their weight off a tee like that.
  #6 (permalink)
Old 07-15-2008, 10:04 PM
Paul Kondzich Paul Kondzich is offline
Is that home made connection to the draft hood acceptable?
Paul Kondzich
www.altitudehomeinspection.com
  #7 (permalink)
Old 07-16-2008, 05:55 AM
Paul,
The back of that connection was leaking CO.
  #8 (permalink)
Old 07-16-2008, 06:08 AM
Nick Ostrowski Nick Ostrowski is offline
Leaking because of lack of proper support on the tank or leaking because of all the polybutylene piping?
  #9 (permalink)
Old 07-16-2008, 06:41 AM
John Arnold John Arnold is online now
Quote:
Not even close.
  #10 (permalink)
Old 07-16-2008, 06:55 AM
You're such an elitist John.
  #11 (permalink)
Old 07-16-2008, 07:07 AM
Quote:
Yes, but I'm a bitter elitist.
Very, very bitter.
  #12 (permalink)
Old 07-16-2008, 08:17 PM
What is not even close, I am lost. Yes the PB is in bad shape, even with the copper fittings. The manifold was corroded.
Similar Threads
Expansion tanks mathew stouffer Plumbing System: Home Inspection and Commercial Inspection 1 04-28-2008 09:33 AM
Expansion tanks mathew stouffer Plumbing System: Home Inspection and Commercial Inspection 0 04-28-2008 09:30 AM
Patina at copper water lines Reis Pearson Plumbing System: Home Inspection and Commercial Inspection 1 03-12-2008 05:19 PM
thermal expansion/ closed water system Jerome W. Young Plumbing System: Home Inspection and Commercial Inspection 7 02-14-2008 04:51 AM
Water supply lines in attic dan orourke Plumbing System: Home Inspection and Commercial Inspection 1 07-14-2007 05:57 PM
vB.Sponsors
Ad Management by RedTyger
