Old 07-21-2008, 02:46 PM
mathew stouffer mathew stouffer is offline
Sump pump installation
I can't find anything regarding sump pump drain line requirements, although I thought garden hose would not make the approved materials list. Is this acceptable?
Old 07-21-2008, 02:48 PM
Re: Sump pump installation
I forgot this jem.
Old 07-21-2008, 02:49 PM
Scott Patterson's Avatar
Scott Patterson Scott Patterson is online now
Quote:
Well, since the trash can manufacturer did not intend for it to be used as a sump I would not worry much about the garden hose!
That is a very poor installation of a sump. It does nothing at removing the ground water(below the grade), the way that thing is installed water has to enter into the crawl space and be flowing several inches before it ever enters the sump. Now if you have pulled it out of its hole, then my comment is a moot point.
I'm betting that cord on the pump is plugged into an extension cord and then that cord goes to who knows where.
Scott Patterson
Old 07-21-2008, 02:51 PM
wayne soper's Avatar
No no good. Not acceptable. "But we never got any water in there anyway so never mind". Water marks? What water marks?
On second thought. Mabey that was a bait well for the guys boat and he was just storing it there. HAHA
  #6 (permalink)
Old 07-21-2008, 08:02 PM
The whole thing was a piece of crap, but I was curious about the garden hose. Moreover, the hose was about thirty feet long.
  #7 (permalink)
Old 07-21-2008, 11:16 PM
Patrick Martinez Patrick Martinez is offline
Hey Matthew,
this looks like a great attempt at maintaining head pressure across the pump, or maybe the screeching noise it makes is the telltale it works, Barely!
I haven't seen anything for sumps for that purpose. My concern(s) would be the discharge termination, so it does not erode any ground around the end of line.
The discharge port if the pump looks to be 1-1/4", it should run undiminished in size to it's termination.
Hope this helps,
Pat
  #8 (permalink)
Old 07-22-2008, 12:00 AM
Jon Randolph Jon Randolph is offline
Decreased discharge piping = decreased flow
Decreased flow = more/harder work for the pump
Harder working pump = decreased life expectancy
dead pump = water / moisture intrusion
Honestly, if the manufacturer of the pump wanted a garden hose connection, it would have been 3/4" instead of 1-1/4". Combine that with an improper garbage can sump pit not being installed at/below the footer and the whole thing needs to be redone.
Integrity Inspection Service, LLC
www.irsindy.com
(317) 345-1828
Home inspection
Similar Threads
Outdoor sump pump GFI? Matt Fellman Electrical Systems: Home Inspection and Commercial Inspection 2 07-10-2008 02:28 PM
Here's where you plug in the sump pump Eric Laney Electrical Systems: Home Inspection and Commercial Inspection 1 04-25-2008 05:21 PM
103 Degree Water in Sump Pit Nick Ostrowski Sub-Structure: Home Inspection and Commercial Inspection 12 01-25-2008 02:43 PM
Cheap Man's Sump David Banks Plumbing System: Home Inspection and Commercial Inspection 6 04-17-2007 07:57 AM
Ejector and sump pumps john m graham Plumbing System: Home Inspection and Commercial Inspection 11 04-06-2007 09:12 PM
vB.Sponsors
Ad Management by RedTyger
