Old 07-25-2008, 06:05 PM
Rick Hurst's Avatar
Water heater question
Came across a gas water heater this afternoon that is puzzling me.
First it had a device in the drain pan that was for shutting off the water heater I suppose if the pan filled with water. There was some type of a electrical circuit board (in a plastic bag) laying inside the drain pan. A white alarm type box also layed in the pan but was not connected to any of the wiring. The drain line on the pan was capped off.
There was a device connected onto the cold water side of the plumbing lines with wiring to the circuit board in the pan.
The shut off valve was located on the hot water side of the tank on the return lines. Strange thing is though is that both copper flex lines were extremely hot to touch.
Any ideas? As Brett Michaels says, "Whatsa going on?"
Rick
I got the reduced copper line on the T&P by the way.
F.I.R.E. provides fireplace education, consulting services, fire investigation and litigation support across the United States.
Old 07-25-2008, 06:36 PM
Richard Moore's Avatar
Richard Moore Richard Moore is offline
Re: Water heater question
Flood Stop Water Heater Auto Shut Off Valve 3/4 NPT - FloodStop Systems
It supposed to turn off the water supply, not the heater, in case of a leak.
Richard Moore
Rest Assured Inspection Services - www.rainspect.com
Seattle, Washington
Old 07-26-2008, 08:59 AM
Rick Hurst's Avatar
With this device though is it common that it would make both supply lines on the top of the water heater hot to touch.
What about the shut-off valve being on the hot side and not the cold side?
Old 07-26-2008, 11:18 AM
Rick Cantrell Rick Cantrell is offline
"There was some type of a electrical circuit board (in a plastic bag)"
I like how they put the sensor in a plastic bag to keep it from getting wet.
Rick Cantrell
Old 07-26-2008, 12:27 PM
Quote:
I don't see it doing that. I'd suspect that's a separate issue with the dip tube or heat trap.
Ummm...in your second photo, I can see a shut-off on the cold line. It's near the wall behind the solenoid and the tee.
Richard Moore
Seattle, Washington
HomeGauge Reports
Similar Threads
Water Heater Clearance Question Greg Subick Electrical Systems: Home Inspection and Commercial Inspection 11 04-23-2008 08:45 PM
Water heater electricity question Sheryl Davidson Electrical Systems: Home Inspection and Commercial Inspection 19 02-13-2008 07:37 PM
Water Heater Question fritzkelly Plumbing System: Home Inspection and Commercial Inspection 15 01-05-2008 05:18 AM
Question about water heater Sheryl Davidson Plumbing System: Home Inspection and Commercial Inspection 5 11-08-2007 08:37 PM
Water heater Question Jeff Eastman Plumbing System: Home Inspection and Commercial Inspection 2 04-12-2007 04:29 PM
vB.Sponsors
Ad Management by RedTyger
