Old 05-05-2007, 01:15 PM
wayne soper's Avatar
wayne soper wayne soper is online now
New one to me
Anyone seen one of these before? I haven't.
Home inspection
Old 05-05-2007, 01:32 PM
Dom D'Agostino Dom D'Agostino is offline
Re: New one to me
I guessing they use it to drain the water line for the Winter without using a bucket?
Dom.
Old 05-05-2007, 01:58 PM
Re: New one to me
I like that one. MAkes sense. Any other ideas out there?
Old 05-05-2007, 02:48 PM
Victor DaGraca's Avatar
Victor DaGraca Victor DaGraca is offline
Re: New one to me
Was there a trap just below?
Mike Huppi Mike Huppi is offline
Re: New one to me
If thats the case wouldn't you need a back flow valve on the line.
  #6 (permalink)
Old 05-05-2007, 02:56 PM
Re: New one to me
No, No trap below.
  #7 (permalink)
Old 05-05-2007, 08:06 PM
Re: New one to me
Major, major cross connection.
Great potential for contamination of the potable water supply.
  #8 (permalink)
Old 05-05-2007, 08:09 PM
James Duffin James Duffin is offline
Re: New one to me
What are the two 3/4' pipes feeding above?
  #9 (permalink)
Old 05-05-2007, 08:11 PM
Thom Walker's Avatar
Re: New one to me
The cross contamination was what I picked up on. But I do have a question about it. That looks like a disconnect at the potable source. If the two were connected only during the time of draining the lines and if the bib had a backflow prevention device on it, would it still be a cross contamination circumstance?
- Paul Fix
  #10 (permalink)
Old 05-05-2007, 08:17 PM
Re: New one to me
Thom,
I my opinion, yes.
The blue (PEX?) line from the DWV WILL BE contaminated *all the time* from bacteria entering from the waste connection.
That puts the contaminated water right up there at the hose bibb.
If you look closely, you will see two hose bibbs and one line, which means that that 'draining line' is to be moved from hose bibb to hose bibb, you know, so they can make sure they contaminate BOTH potable water lines.
I don't see any backflow preventer either.
For something like that, you would need a major multiple purpose backflow preventer - did you go to the Watts site and order those DVDs? If so, watch the one of Backflow Prevention, if not order them and then watch it.
  #11 (permalink)
Old 05-05-2007, 08:27 PM
Re: New one to me
An indirect waste connection may be another option...like on a reverse osmosis system. No backflow device needed as long as there is an air gap..
  #12 (permalink)
Old 05-05-2007, 08:35 PM
Re: New one to me
Quote:
Which in and of itself is a backflow prevention device. But not all cross connections are allowed to use air gaps as air gaps are not always reliable for the prevention of a cross connection.
Contamination can cross the air gap, spillage, splashing, evaporation, a number of different reasons, including backpressure (in this case, an air gap could overflow if the DWV line clogged and backed up).
  #13 (permalink)
Old 05-05-2007, 08:48 PM
Re: New one to me
They are ordered now.
As I said, I would have called out the cross contamination risk. I just wondered if there was a way to use the idea without cross contaminating.
- Paul Fix
  #14 (permalink)
Old 05-05-2007, 08:54 PM
Re: New one to me
This simple 1/4" darin hose could dump into an air gap without a RPZ device I believe. Please share with us your acceptable connection.
  #15 (permalink)
Old 05-14-2007, 10:39 PM
Re: New one to me
Quote:
I got them last night and watched them tonight. The one on scalding should be watched by everyone on the planet.
- Paul Fix
  #16 (permalink)
Old 05-15-2007, 07:51 AM
Gunnar Alquist's Avatar
Re: New one to me
I must have missed the post about the Watts DVD. I went to their site and was unable to find the link. Can you help?
What is the circumference of a moose?
  #17 (permalink)
Old 05-15-2007, 07:56 AM
Re: New one to me
Learn About - Danger Scalding Lurks! Free DVD, hot water scald, safety mixing valve
- Paul Fix
vB.Sponsors
Ad Management by RedTyger
