We were called over to this house to fix the problems because the inspector failed the previous plumber. Wonder why! There was actually more wrong under the house but I haven't snapped any photos of that yet. They include using silicon to join pipe and fittings, an impressive custom-trap job, and pipe sloping the wrong direction. Done by a plumber with 40 years experience.
For the ones not TOO obvious:
0004, the 90 is a dry vent
0007, that's an offset flange, because 12" would've meant he would cut a floor joist, which he had no problem doing elsewhere. Plus 10" would have worked fine.
0011, that's a dry vent.
Were you doing a construction inspection or a warranty inspection? If it was during construction then you should advise the client to call the AHJ as to why they passed the work.
About a year ago, a man approached us on a jobsite saying he needed a plumber for a little remodel. We had to turn him down though, we were in the middle of a large commercial job (completely renovating an 80-year old apartment complex with 55 units) and weren't able to help him at the time. We met up with him again at the apartments recently and was told the plumbing failed, and he asked us over to explain some of the things marked off since he didn't know the lingo. The original plumber did this mess and charged the guy $5,000 for it, it comes out to about $1000 per fixture.
Jerry, 0005 is a trap pushed up about as high as it will go to the bottom of the floor. Then there's a verticle offset, then a horizontal offset, before going into that combo. I can't remember, but I think the combo picks up a sink.
It's a problem because the dry vent is being run horizontally. Dry vents shouldn't be run flat like that until they're 6" above the flood rim of the fixture they're venting.
All Rights Reserved. Hann Tech Marketing Link / InspectionNews.com / InspectionNews.net - No part of InspectionNews.net may be reproduced in any way, or by any means, without the prior written permission of InspectionNews.net. Use of any index or listing Software for the purpose of constructing a mailing list, creating promotional materials or producing a printed or electronic catalog of any kind is expressly forbidden without the prior written permission of InspectionNews.net - All text, graphics and design on InspectionNews.net is copyright by Hann Tech Marketing Links. Ad Management by RedTyger
