Old 08-07-2008, 08:32 PM
Trent Tarter Trent Tarter is offline
Protective vehicle stop (bollards) in garage
I inspected a 2005 built home today with a gas water heater located in garage. No vehicle protection or (bollards) were installed in front of the gas water heater. The water heater sits off to the front corner and is not in direct path with an incoming vehicle that is if your coming in straight. I am thinking that protection is still needed. What is the code or standard for vehicle protection.
Old 08-07-2008, 08:50 PM
Rick Hurst's Avatar
Re: Protective vehicle stop (bollards) in garage
Trent,
I've never seen bollard protection as of yet and will probably have a stroke the first time I see them.
IRC code {1307.3.1} states, In garage-protect from damage by vehicles
Old 08-07-2008, 08:51 PM
Quote:
That it is required.
P2801.2 Installation. Water heaters shall be installed in accordance with this chapter and Chapters 20 and 24.
G2408.3 (305.5) Private garages.Appliances located in private garages shall be installed with a minimum clearance of 6 feet (1829 mm) above the floor.
- Exception: The requirements of this section shall not apply where the appliances are protected from motor vehicle impact and installed in accordance with Section G2408.2.
M1307.3.1 Protection from impact. Appliances located in a garage or carport shall be protected from impact by automobiles.
Old 08-07-2008, 08:54 PM
Quote:
At which time you will stop writing them up ... right?
Old 08-07-2008, 09:01 PM
Rick Hurst's Avatar
Only if they can pull the pen from my dead hand. Didn't Heston say something like that?
  #6 (permalink)
Old 08-07-2008, 09:05 PM
Billy Stephens's Avatar
Billy Stephens Billy Stephens is offline
Rick,
And what do you think all those Xmas Decorations, like New Sports Equipment & assorted ? Collectibles ! ( function is if not to protect the WH ?)
Billy J. Stephens HI Service
Similar Threads
Garage gap Ryan Stouffer H E L P ! 8 05-28-2008 10:33 AM
TX vehicle tax John Brown Business Operations: Home Inspectors & Commercial Inspectors 16 03-12-2008 11:03 AM
Water heater - vehicle impact Jeff Eastman Plumbing System: Home Inspection and Commercial Inspection 12 07-30-2007 01:11 PM
Insulation over garage M Kelekci Attic Areas: Home Inspection and Commercial Inspection 14 07-23-2007 07:46 PM
Moisture stop, brick ledge John Stephenson Building Envelope: Home Inspection and Commercial Inspection 1 06-05-2007 04:08 PM
vB.Sponsors
Ad Management by RedTyger
