Old 05-07-2007, 02:14 PM
dan orourke dan orourke is offline
Water Heater Location
Home inspection
Old 05-07-2007, 07:24 PM
Re: Water Heater Location
Quote:
Originally Posted by dan orourke View Post
Electric water heater is located in the washer/dryer room, 2 feet from the laundry room to garage door.
Does the water heater need to be elevated due to the lower eletrical element providing an ignition source to vapors, fumes etc. from the garage if door is left open?
If the water heater is not "in" the garage, i.e., the laundry room has a door to the garage and to the house, making the laundry room "not in" the garage, then no.
If the laundry room is off the garage (a door opens from the garage into a laundry closet "in" the garage), then yes. However, that closet is likely to be raised above the garage floor, in which case it may have raised the lower element up high enough already.
Home inspection
Similar Threads
Water heater Leak? K Robertson Plumbing System: Home Inspection and Commercial Inspection 5 04-30-2007 09:22 PM
gas water heater location wes owens Plumbing System: Home Inspection and Commercial Inspection 5 04-29-2007 09:52 AM
Water heater valve Gregg Austensen Plumbing System: Home Inspection and Commercial Inspection 9 04-24-2007 08:06 PM
Water Heater Location Jeff Eastman Plumbing System: Home Inspection and Commercial Inspection 2 04-14-2007 09:52 PM
Water heater Question Jeff Eastman Plumbing System: Home Inspection and Commercial Inspection 2 04-12-2007 03:29 PM
vB.Sponsors
Ad Management by RedTyger
