Old 08-15-2008, 07:02 AM
fritzkelly fritzkelly is online now
Another water heater explodes
Amazing that no one seems to have a clue how this happens.
Good Morning Yahoo!
Old 08-15-2008, 08:09 AM
Jerry McCarthy's Avatar
Re: Another water heater explodes
You would think the local firemen would be familiar with a water heater's PTRV and what "may" happen should it not release when pressure builds up?
Construction Consultant
Old 08-15-2008, 09:39 AM
Quote:
One would think so.
Golly, Ah sur don no why dat ting sploded like dat, Ah mean thar thwartnt no gas ta it.
Old 08-15-2008, 12:15 PM
When I saw a report on the news this morning, they were saying it was a suspected gas leak when they zoomed in on the tank. I could see it was no gas leak, the tank exploded and became a missile. I guess since we so rarely see this we can be thankful that the TPR requirements are working, not 100%, but working.
How much you want to bet that was a DIY job and they find a plug in the line?
Mr. Inspector.net, Inc.
Allen, Texas 75002
Old 08-15-2008, 12:40 PM
You guys did notice, I presume, that that was not an "old" tank. Many of the tanks which blow are "old" tanks.
That one is since the 1990s when they started using foam insulation outside the tank instead of fiberglass insulation. There is foam still attached to the tank.
Just had a thought ... maybe that was the problem ... foam chunks fell off during lift off and ...
  #6 (permalink)
Old 08-15-2008, 01:26 PM
What that WH looked like before it became a missle, you think?
  #7 (permalink)
Old 08-15-2008, 05:01 PM
Bruce Ramsey's Avatar
Bruce Ramsey Bruce Ramsey is offline
I was a firefighter for a while. There is plenty of book learning to become a firefighter. There is pleny of field training. How to carry, set, and climb ladders. Hydrodyamics of water through various size hoses, inflow of water from a 5 inch hydrant to muliple 3 inch hoses and the approxmiate water flow to the fire. Levels of oxygen vs flamable vapors, flash points. Of course all firefighters have to also be EMT so ongoing medical training. Hazardous Materials are every looming and all the various protocols to keep the firefigher safe, contain the hazmat problem and keep the public from interfering. There are three levels of Firefighter, with associated classroom and field training. Firefighers are sorted into engine companies and ladder companies with different duties and training. Lets not forget officer leadership training.
There are lists of additional cerfiications in all kinds of hazards. Swiftwater, Confined Space, Trench, Farm Machinery, Rope, Building Collapse, Vehicle extrication, SAR, etc. Each of those displines has at least a 40 hour classroom requirement. And each of those requires constant refresher courses to keep the certication active.
If TPRs are functioning, firefighters never hear about them. When they fail, they only see the results. Don't care how it happened, just clean up the mess.
We see everyday that even plumbers don't know about TPR and the proper installation. Failing safety valves are very low on the list of things firefighters learn about.
Bruce Ramsey
Advocate Inspections
www.NCAdvocate.com
  #8 (permalink)
Old 08-15-2008, 05:32 PM
imported_John Smith imported_John Smith is offline
Im glad it wasnt a house I inspected. Electric or gas, it doesnt matter - pressure beyond the maximum allowable working pressure of the tank will result in failure. Usually they leak (by design) before they launch like a missle.
  #9 (permalink)
Old 08-15-2008, 07:15 PM
Ah, er, John, are you saying that an operable PTRV is not significant in preventing what we are all seeing in the main thrust of this thread? I agree, anything in water, holds water, keeps water out, or repels water eventually leaks. Not a comforting thought if I where a submariner. However, that's the nature of how things work, sort of like home inspectors who say they have never been sued.............................................. ......... for which I say that’s a “yet.”
  #10 (permalink)
Old 08-15-2008, 07:43 PM
Brian Thomas Brian Thomas is offline
Im not surprised that most people automatically suspect a gas leak when something explodes like that. I dont think that many people outside of plumbers and HI and people in this type of field even know what a TPR valve is, much less what its designed to prevent!
BY the way, nice pic WC Jerry! I wonder if he would have trouble collecting insurance on that if it was known that the TPR valve was purposely plugged like that
  #11 (permalink)
Old 08-15-2008, 07:56 PM
Rick Cantrell Rick Cantrell is offline
I don't know this for a fact, but I've heard, that if a heating element corrodes into, it will break down the water into hydrogen and oxygen gases, that are released into the water tank. Then it can be ignited by the broken element. If that is so, then no PTRV in the world would help.
Rick Cantrell
  #12 (permalink)
Old 08-15-2008, 08:28 PM
Billy Stephens's Avatar
Billy Stephens Billy Stephens is offline
Quote:
That would require the tank to very low to allow a large volume of gas to be present for the type of damage that was reported.
Tank would also be ripped into multiple pieces instead of launched through the structure and landing more than a block away.
Billy J. Stephens HI Service
  #13 (permalink)
Old 08-15-2008, 09:50 PM
The real myth is that this is "caused" by a faulty TPR valve, its not, its caused by a faulty thermostat and a faulty TPR valve. So, why aren't we testing thermostats?
Jerry, those "new" tanks are old now, I hate to tell you, 1990 was 18 years ago, pretty old in water heater years.
(I think 1 human year is 5 water heater years)
  #14 (permalink)
Old 08-15-2008, 10:29 PM
Bruce King Bruce King is offline
Since the electric water heaters also have a thermal cut out switch, a bad thermostat and bad TPRV does not always cause a tank launch.
Seems like you would need 3 failures or 2 failures and one plugged TPRV port.
I had a tank with a bad thermostat once that got very hot, the TPRV did not discharge at all, the overtemp cutout tripped and shut it off. A new thermostat and a push in on the red button and all was well.
Here is some related info on bulging water heaters from AO Smith
http://www.hotwater.com/bulletin/bulletin41.pdf
  #15 (permalink)
Old 08-16-2008, 05:17 PM
allen elliott allen elliott is offline
Jerry M. can you clarify the reason for fireman comment?
  #16 (permalink)
Old 08-16-2008, 05:33 PM
Randy Aldering Randy Aldering is offline
That fire captain needs to follow one of us around on a few home inspections.
Randy Aldering, RHI CHI
Housesmithe Home Inspection
www.housesmithe.com
  #17 (permalink)
Old 08-16-2008, 07:09 PM
Michael Thomas's Avatar
Ya' can't make this stuff up: posted yesterday at doityourself.com
"I wouldn't necessarily call it a "leak", but I noticed a small amount of water (not puddling and about 4 inches x 8 inches) directly next to my hot water tank yesterday, and it is still there today. I am pretty sure the water is from the tank, as there is nothing else that could have caused the water to be there.
I live in Phoenix and the hot water tank is in my garage. It is about 110 outside and 120-130 in the garage.
Should I have the tank serviced?"
- Hot Water Leak Normal ? - DoItYourself.com Community Forums
Similar Threads
gas water heater Jerome W. Young Fireplaces, Chimneys and Solid Fuel Burning Appliances: Home Inspection and Commercial Inspection 25 07-19-2008 11:12 AM
Water Heater Seth Hughes Plumbing System: Home Inspection and Commercial Inspection 10 06-07-2008 07:56 PM
Hot Water Heater Tom Rees Plumbing System: Home Inspection and Commercial Inspection 3 04-02-2008 09:35 PM
Water Heater Jeff Eastman Plumbing System: Home Inspection and Commercial Inspection 5 07-23-2007 06:31 PM
Who's Water Heater is This Shane Pouch Plumbing System: Home Inspection and Commercial Inspection 3 05-11-2007 08:06 PM
vB.Sponsors
Ad Management by RedTyger
