Originally Posted by
Chris Stichter
Is there pvc rated for tpr drain lines?
Gunnar Alquist
There is a plastic drain pipe that is rated and it is specifically labeled.
CPVC is rated for that use.
As Gunnar said, there is (someone posted a photo of it) a PVC or PVC looking plastic T&P discharge line made and rated for that use, with the standard it was tested to stamped on it and the product approval stamped on it.
Either that information was stamped on it, or it was just marked as 'Suitable for use as temperature and pressure relief valve discharge line.' - but without the other markings and we questioned its approval for that use.
I don't remember whether it had the approvals on it or not.
Anyone remember those posts and that photo?
As Gunnar said, have the plumber "prove it", because unless he can "prove it", the answer is no, it is not allowed, which is what you stated.
From the 2006 IRC.
- P2803.6.1 Requirements for discharge pipe. The discharge piping serving a pressure-relief valve, temperature-relief valve or combination valve shall:
- - 13. Be constructed of those materials listed in Section P2904.5 or materials tested, rated and approved for such use in accordance with ASME A112.4.1.
TABLE P2904.5
WATER DISTRIBUTION PIPE
MATERIAL ------------------------------------------------ STANDARD
Brass pipe ------------------------------------------------ ASTM B 43
Chlorinated polyvinyl chloride (CPVC) plastic pipe and tubing - ASTM D 2846; ASTM F 441; ASTM F 442; CSA B137.6
Copper or copper-alloy pipe -------------------------------- ASTM B 42; ASTM B 302
Copper or copper-alloy tubing (Type K, WK, L, WL, M or WM) -- ASTM B 75; ASTM B 88; ASTM B 251; ASTM B 447
Cross-linked polyethylene (PEX) plastic tubing ---------------- ASTM F 877; CSA B137.5
Cross-linked polyethylene/aluminum/cross-linked polyethylene (PEX-AL-PEX) pipe - ASTM F 1281; CSACAN/CSA-B137.10
Cross-linked polyethylene/aluminum/high-density polyethylene (PEX-AL-HDPE) - ASTM F 1986
Galvanized steel pipe ---------------------------------------- ASTM A 53
Polybutylene (PB) plastic pipe and tubing --------------------- ASTM D 3309; CSA CAN3-B137.8
Polyethylene/aluminum/polyethylene (PE-AL-PE) composite pipe - ASTM F 1282
Polypropylene (PP) plastic pipe or tubing ----------------------- ASTM F 2389; CSA B137.11
Stainless steel (Type 304/304L) pipe -------------------------- ASTM A 312; ASTM A 778
Stainless steel (Type 316/316L) pipe -------------------------- ASTM A 312; ASTM A 778
As you can see, PVC is not in Table 2904.5 and is thus not allowed, unless it is "materials tested, rated and approved for such use in accordance with ASME A112.4.1." - thus if it does not state that it is ASME A112.4.1 approved, it is not allowed to be used for that use.
