Old 08-25-2008, 02:56 PM
wayne soper's Avatar
CSST to copper
CSST today, new home. Can we use this copper pipe in ths way? Yes we can. What about ground to manifold. Yes we need one.
Old 08-25-2008, 06:57 PM
Re: CSST to copper
Is that a plastic manifold? If so, each CSST would need its own ground bond. If the manifold is metal, and the copper is bonded, then no bond is needed at the manifold.
Those look like those pre-soldered fittings which are slipped together and then heated. Are they approved for use with gas?
Not all copper is approved for use with gas, and not with all types of gas.
Old 08-26-2008, 06:16 AM
Re: CSST to copper
No Jerry, Iron manifold, couldn't tell if the meter was grounded. Couldn't get to it. Storage. Called it as check by installing plumber.
Copper pipes are crimped which is allowed although the first time I have seen it used for gas application.
Old 08-26-2008, 07:31 AM
Victor DaGraca's Avatar
Victor DaGraca Victor DaGraca is online now
Re: CSST to copper
I don't know if it's just the colors in the picture, but, that appears to be "white" teflon tape used on those threads.
"White" teflon tape is not allowed for gas connections.
Don't ask me why or where it is specifically prhibited by any regulatng agency, but, I do remember the packaging specifically stating that it is not to be used for gas applications.
www.Home2Spec.com
Old 08-26-2008, 08:09 AM
Re: CSST to copper
Here are some varieties of Teflon pipe sealant tape: Adhesives > Thread and Gasket Sealants > Pipe Sealant Tape : Grainger Industrial Supply
It's not the color, but what it is rated for.
Quite probably, 'seeing yellow' means that there is no mistaking non-rated tape for that use, however, it may also be possible that there is a non-yellow tape rated for that use - "possible" - I tried searching the Dupont site got some page errors, but mostly information which was not linked to anything to check further???? Not real helpful for a web site from such a large company.
  #6 (permalink)
Old 08-27-2008, 10:16 AM
brian schmitt brian schmitt is offline
Re: CSST to copper
wayne,
fittings are "viega" pro press brand. they also make pex tubing. they have to be marked for gas application. they are solderless crimped fittings.
  #7 (permalink)
Old 08-27-2008, 12:00 PM
Re: CSST to copper
Thanks Brian, good info!!Marked meaning a stamp on the pipe? or a tag indicating it is being used as a gas line to prevent the three stooges from cutting it?
  #8 (permalink)
Old 08-27-2008, 02:04 PM
Re: CSST to copper
wayne
gas is marked with a yellow spot.
  #9 (permalink)
Old 08-27-2008, 02:39 PM
Rick Cantrell Rick Cantrell is offline
Re: CSST to copper
This is off topic, but when I read "to prevent the three stooges from cutting it", I gotta tell this story.
I was remodeling a house I bought. 3 guys working for me, I had to go out of town for a few days. When I returned I found that they had connected the water (galv being replaced with copper) to the gas pipe (black). You can only imagine my reaction. Talk about 3 stooges.
Rick Cantrell
  #10 (permalink)
Old 08-27-2008, 05:44 PM
Re: CSST to copper
Thanks Brian, that spot would be applied by the plumber as a visual aid. correct?
Home inspection
Similar Threads
CSST Clearance Stuart Brooks Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 4 07-06-2008 03:38 PM
CSST and return air mathew stouffer Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 10 06-27-2008 04:49 PM
CSST Mike Parks Safety Recalls and Notices 24 05-08-2008 06:45 AM
csst wayne soper Plumbing System: Home Inspection and Commercial Inspection 4 07-09-2007 06:14 PM
CSST bonding Thom Walker Plumbing System: Home Inspection and Commercial Inspection 7 05-09-2007 09:29 PM
vB.Sponsors
Ad Management by RedTyger
