Old 08-25-2008, 03:18 PM
Chris Stichter Chris Stichter is offline
Hose bib question
Are there requirements as to the number and location of exterior hose bibs? Are there any code references to this matter?
As always, thank you for your help.
Chris
Old 08-25-2008, 06:53 PM
Re: Hose bib question
The old South Florida Building Code required a hose bibb at the front and the rear of every dwelling unit.
The rest of the state which was under the Standard Building Code did not have that requirements, neither do the ICC codes.
It makes "common sense" to have at least one at the front and one at the rear, but the "code of common sense" is 'uncommon' in today's buildings.
Old 08-25-2008, 09:17 PM
In this case there are 2 bibs on the sides of the home (none in the backyard). The builder agreed that there should be one in front & one in back until they realized it was one of there spec homes.
They then retracted that statement & said there is no "code" stating such.
I guess the common sense does not apply here.
Anyone run into a similar situation?
Old 08-28-2008, 10:59 PM
Joshua Hardesty Joshua Hardesty is offline
I always try to put at least two on opposite corners of the house, so one hose could cover two sides. But I'm always glad to add more.
Old 08-29-2008, 05:54 AM
Ken Amelin Ken Amelin is offline
Our state (MA) requires a minimum of two outside hose bibs with additional ones required so that there is no greater than 100 ft. between them as measured on the perimeter.
  #6 (permalink)
Old 08-29-2008, 06:42 AM
Gary Smith's Avatar
Gary Smith Gary Smith is offline
When I start a home I usually study the plan with my plumber and ask him to place them around. I try to place at least one on each side of the box...front, back, and two sides or and maybe near the drive to wash the auto. Of course the most convenient spot to place them is nearer the bath or kitchen. That way the plumber doesn't have too much material cost tied up in hose bibs piping. I've not run into a code that "required" them but it would be fairly stupid to build a home without using good common sense not only in their placement but in not placing them at all....and like Jerry said...common sense is sometimes pretty uncommon.
Blog | Home Page | Order Inspection
Serving Central MS Since 1974 Call Toll Free 877.809.6139
Similar Threads
Grounding rod directly below Hose bib Ted Menelly Electrical Systems: Home Inspection and Commercial Inspection 2 06-16-2008 03:27 PM
hose test CHARLIE VAN FLEET Building Envelope: Home Inspection and Commercial Inspection 19 06-07-2008 06:25 PM
vB.Sponsors
Ad Management by RedTyger
