Old 08-26-2008, 02:37 PM
allen elliott allen elliott is offline
Composition boot used for flashing
I believe this one falls under the 1"(and common sense) to combustibles rule. I am posting it to be sure there is no rule that allows this. An ordinary composition boot is used for the flashing for the water heater flue. I also noted the missing cap. The furnace flue was a different issue.
Thanks for input.
Home inspection
Old 08-26-2008, 02:41 PM
Re: Composition boot used for flashing
No exception allowing this, 1" clearance to combustibles would specifically prohibit plus the need to use the listed flashing component with the b-vent.
Don't forget the height of the flue above the roof.
Mr. Inspector.net, Inc.
Allen, Texas 75002
Old 08-26-2008, 05:28 PM
Thanks Jim!
Similar Threads
Minimum pitch for three tag composition shingles. Lamar Bruce Introductions By New Members 5 08-04-2008 05:47 AM
Flashing do you see anything Ron Bibler Tools and Equipment 8 06-28-2008 05:24 PM
Flashing Reis Pearson Roofing System: Home Inspection and Commercial Inspection 4 03-16-2008 11:07 AM
Composition shingle over wood shakes Dave Boratyn Sub-Structure: Home Inspection and Commercial Inspection 12 10-15-2007 07:43 PM
Roof Jack w/ Neoprene Boot At B Vent Bruce Breedlove Roofing System: Home Inspection and Commercial Inspection 6 04-03-2007 02:14 PM
vB.Sponsors
Ad Management by RedTyger
