Old 05-10-2007, 11:34 AM
John Stephenson John Stephenson is offline
Water heater copper flex
Old 05-10-2007, 02:03 PM
Scott Patterson's Avatar
Re: Water heater copper flex
The TPR manufacturer specifies that the pipe can not be reduced. A flex pipe does not have the same inside diameter past the connection point.
Scott Patterson
Similar Threads
gas water heater fittings wes owens Plumbing System: Home Inspection and Commercial Inspection 7 05-10-2007 03:28 PM
Water heater Leak? K Robertson Plumbing System: Home Inspection and Commercial Inspection 5 04-30-2007 09:22 PM
gas water heater location wes owens Plumbing System: Home Inspection and Commercial Inspection 5 04-29-2007 09:52 AM
Water heater valve Gregg Austensen Plumbing System: Home Inspection and Commercial Inspection 9 04-24-2007 08:06 PM
Water Heater Location Jeff Eastman Plumbing System: Home Inspection and Commercial Inspection 2 04-14-2007 09:52 PM
vB.Sponsors
Ad Management by RedTyger
