    Wendell Swedberg's Avatar
    Wendell Swedberg Guest
    Default Plumbing definitions
    Could clear up some basic plumbing definitions for me? I'm getting confused on the IRC's usages....
    - A Lavatory?
    I always thought a lavatory is a the entire bathroom fixture components (sink, toilet, tub, shower, etc). Seems IRC just refers to it as a toilet?
    - A Water Closet?
    I always thought a water closet was just a toilet and a sink. Seems IRC just refers to it as a toilet?
    - A Laundry tray?
    I've never heard this term before so I don't have a clue?
    - A Laundry tub?
    I think the IRC means the washer?
    thanks, as I go away feeling very stupid....stupid is as stupid does...
    Default Re: Plumbing definitions
    Quote Originally Posted by Wendell Swedberg View Post
    - A Lavatory?
    That's the bathroom sink.
    - A Water Closet?
    That's the toilet/commode.
    - A Laundry tray?
    Basically think of it as a ...
    - A Laundry tub?
    One of those utility tubs in laundry rooms next to the clothes washer where they 'used to do laundry in' but nowadays just serves as a laundry room sink. The older ones were frequently two or three compartments, the newer ones are just one compartment.
    A laundry tray and laundry tub as basically one and the same.
    I figured the laundry tray as being that pan on the wall around the cold / hot faucets and the drain pipe.
    What is that thing actually called?
    Garland, TX
    Dec 2007
    Holladay, UT
    I thought the laundry tray was the pan under the washer that is connected to a drain, for use in areas (such as second floor) where broken hose etc. could cause water damage. Just my thought on it.
    http://acloserlookslc.com/
