04-18-2008, 04:20 AM
drain venting
2005 house; the pool and spa had pipes that appeared to be vent pipes for the drains, but htey were capped off. Both the pool and spa had two drain locations with anti vortex covers. Am i missing something? these vents are not needed? or ?
04-18-2008, 07:54 AM
Re: drain venting
If (because I can't see the rest of the piping & equipment) those pipes are part of the Suction Limiting Vent System, they need to be open to the atmosphere with tamper resistant covers. If a high vacuum event occurs, the air from the vents breaks the suction.
Dom.
04-18-2008, 08:46 AM
Re: drain venting
Typically I see two 90 degree elbows installed on top of those, leaving the opening down-turned.
As Dom said, they need to be open.
04-20-2008, 06:06 PM
Re: drain venting
Could this be for future plumbing? I didn't see where the pipes were connected to the pool equipment. I've seen this when folks plan a fountain, or other water feature.
Just came to mind when I saw the pics.
Take it easy
| Thread Tools |
Search this Thread |
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
| Plumbing/venting |
Richard Roshak |
4 |
04-12-2008 07:19 PM |
| HE Flue Venting |
Jim Robinson |
1 |
02-18-2008 08:26 PM |
| h2o venting |
cris donato |
4 |
01-10-2008 12:41 PM |
| Venting Issues |
Michael Thomas |
6 |
11-18-2007 01:50 PM |
| Venting for gas fireplace |
Jon mackay |
Fireplaces, Chimneys and Solid Fuel Burning Appliances: Home Inspection and Commercial Inspection |
3 |
06-19-2007 06:01 AM |
Ad Management by
RedTyger
