Old 09-27-2008, 06:47 AM
Jerome W. Young Jerome W. Young is offline
pump strainer drain?
Anyone know what this is exactly and what it is for? Never seen one. it had a valve and a tube that appears to be used to drain the strainer baset area.
Home inspection
Old 09-27-2008, 08:38 AM
Re: pump strainer drain?
Jerome,
I don't recall having seen one before either, but it may have a different purpose.
While it is located at the bottom of the strainer basket where a drain would be, I can't think of why it would have a drain there (and none of the ones I've seen had a drain there), so, maybe it is for an intake from a chlorination unit?
That strainer basket is under negative pressure, so it would be sucking in whatever was being fed into that tube.
Looks like the red coupling/connector end is broken, which may be why the two pieces are separated.
(I rotated the photo so 'up' is 'up'. Either that or Von has an uncanny ability to stand horizontally from the side of vertical surfaces. )
Old 09-27-2008, 01:24 PM
Dom D'Agostino Dom D'Agostino is online now
Almost every pool pump has a drain port (or 2) in the bottom, but not a valve like that. That looks like a Hayward pump. The drain ports are for "winterizing" the equipment.
What was on the other end of the disconnected hose/line?
Old 10-02-2008, 04:15 PM
nothing was attached , strange
Old 10-02-2008, 04:23 PM
Rick Hurst's Avatar
Rick Hurst Rick Hurst is online now
As Dom said it is probably for winterizing the pump housing.
  #6 (permalink)
Old 10-02-2008, 06:14 PM
Quote:
In Vero Beach?
Of course, though, I guess there 'are' areas of the country where things 'do' need to be winterized.
  #7 (permalink)
Old 10-02-2008, 06:46 PM
Rick Hurst's Avatar
Got me there. I didn't notice where Jerome was from.
Maybe its a water balloon fill tube.
  #8 (permalink)
Old 10-02-2008, 06:57 PM
Billy Stephens's Avatar
Billy Stephens Billy Stephens is offline
Quote:
In Vero Beach?
A Yankee Brung It With Him.
Billy J. Stephens HI Service
  #9 (permalink)
Old 10-08-2008, 12:16 AM
Joe Klampfer's Avatar
Joe Klampfer Joe Klampfer is offline
Quote:
Kinda looks like a pressure switch or a water level switch to prevent the system from being energized while dry ??
Similar Threads
Here's where you plug in the sump pump Eric Laney Electrical Systems: Home Inspection and Commercial Inspection 1 04-25-2008 06:21 PM
Recirculating Pump Tom Rees Plumbing System: Home Inspection and Commercial Inspection 8 03-10-2008 08:19 PM
condensate pump drainage wayne soper Plumbing System: Home Inspection and Commercial Inspection 5 03-10-2008 08:08 PM
Air in Well Pump line Jim Gecz Plumbing System: Home Inspection and Commercial Inspection 6 08-30-2007 07:46 PM
Heat Pump? David Banks Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 15 05-06-2007 02:04 PM
vB.Sponsors
Ad Management by RedTyger
