Thread: lighting in crawl space
01-07-2011, 08:03 AM #1
I am in the process of installing additional lighting in my crawl space. My concern is, are there any restrictions regarding the type of lighting that should be used?
01-07-2011, 01:13 PM #2
Re: lighting in crawl space
I'm not sure about any code requirements but just using logic... I'd GFI protect everything and use closed lights - meaning the type with covers as opposed to open bulbs.
You might just wire up a bunch of switched outlets and use those plug-in fluorescent lights (the kind that are often in closet or over a desk area in a kitchen). They're cheap and safe and easy to install.
01-09-2011, 05:59 PM #3
Around here, open "keyless" light fixtures with bare incandescent light bulbs are standard in crawlspaces and attics. Bulbs are already burned out half the time.
01-10-2011, 03:27 PM #4
