05-27-2011, 07:37 AM #1
Brick
05-27-2011, 11:11 PM #2
Re: Stair step crack in the brick veneer
I would say its probably caused from the lack of brick ties in the wall system.
Rick
05-28-2011, 04:15 AM #3
UYou can get an engineer in for maybe the mid 200s and up. Any foundation company will come in and take measurements and will be able to tell you of total movement of the foundation.
That corner has settled as it continued to open that crack. Has it ever closed and reopened. I love the lousy job of patching the builder did. You should not notice a mortar patch if done by a pro
Horizontal crack may very well indicate lack of wall ties as Rick said but the brick is not going th move unless the home moves around. You may well have some drainage issues.
Of course who knows anything for sure looking at a picture online but I can say that your home has been moving around and you need to get a foundation company or an independent engineer in for evaluation. Thee is.no such thing as normal settling to the point of brick and mortar cracks. There is always a reason behind it.
05-28-2011, 04:59 AM #4
If that wall is the width of what is shown in the picture then it is cracked all the across the width of the wall and that is bad. It means the bricks above the crack are no longer attached to the bricks below the cracks so filling in the crack on the surface will not help structurally. It also looks like the caulking has cracked on the left side where it meets the wood trim. It looks like the fooundation needs to be stablized and the brickwork repaired so the mortar is removed at least half way through the brick and replaced.
05-28-2011, 08:07 AM #5
I think everyone is missing the obvious here. Right side of picture, downspout dumping right at the corner the crack is running to. Extend the downspout out, fix the wall either band-aid style or properly.
05-28-2011, 08:13 AM #6
