Results 1 to 2 of 2
Thread: Gas fire pit
09-23-2011, 11:40 PM #1
Gas fire pit
How far away from a house is a safe distance for a gas fire pit with a 2'6 inside pit area?
09-24-2011, 02:17 PM #2
Re: Gas fire pit
If the gas fire pit is a listed unit, it should state the distance in the installation instructions.
If the gas fire pit is not a listed unit ... it is required to be a listed unit, so don't install it.
If it is is not a listed unit and you install it anyway - WHICH YOU SHOULD NOT DO - install it at least as far away as unlisted open flame items, such as Hibachi grills and other similar grills and devices for charcoal/wood/etc ... the minimum clearance for those units is 10 feet from any part of any structure - BUT ... it should be a listed unit or do not install it.
