Thread: Plumbing question(PVC/CPVC).
10-10-2011, 10:06 PM #1
I live in Chicago(single family home). Can PVC/CPVC be used for interior supply line?
Thanks,
Ceci
10-10-2011, 10:21 PM #2
Re: Plumbing question(PVC/CPVC).
10-11-2011, 05:45 AM #3
PVC is only allowed for drain, waste and vent pipe in the City depending on occupancy status and size of the building. All supply pipe must either be copper or galvanized. Any PVC type supply pipe you put in will need to come out.
10-11-2011, 08:30 AM #4
10-11-2011, 01:00 PM #5
Not a good place to be a Wirsbo salesman. Have they talked about allowing PEX for residential piping? Can you use it for in floor radiant heat in Chicago?
10-11-2011, 05:41 PM #6
You can use the PEX variants for sub slab radiant in the City. PEX has been discussed in the City a bit but the discussion never goes very far. We have enough problems with poor workmanship and DIY around here. Last thing we need is plastic water lines.
PEX is approved though in some suburbs.
