Thread: oil burner and wood/coal stove
11-26-2011, 08:20 PM #1
Can you run a oil burner and a wood/coal stove in the same chimney? If so what is the correct way to connect them? I would like to add a wood stove as my primary heat and just run the oil as back up.
11-28-2011, 05:32 PM #2
Re: oil burner and wood/coal stove
Charles, my 2006 IRC says, at M1801.12 Multiple solid fuel prohibited. "A solid-fuel-burning appliance or fireplace shall not connect to a chimney passageway venting another appliance."
So, you "can", but you should not.
11-29-2011, 03:31 AM #3
call you're insurance company and ask if they will cover the home after it burns down from you're modification.
that makes the answer simple doesn't it?
11-29-2011, 06:06 AM #4
If its done correctly. And your Insurance carrier will need to approve of this set-up in your house.
Hawley’s is Bancroft, Ontario’s choice for your heating, cooling and plumbing solutions, including wood stoves, fireplaces, furnaces, air conditioning, water purification, reverse osmosis, maintenance, service, installation and sales.
