Results 1 to 31 of 31
12-07-2011, 08:01 PM #1
standing water in vented crawlspace
delete delete delete
Similar Threads:Last edited by John Dickerson; 12-08-2011 at 07:22 PM.
12-07-2011, 08:30 PM #2
Re: standing water in vented crawlspace
Hi John
Duplicate Posting the same question under different heading is ill advised.
That said Welcome.
All we ( I ) can see from your pictures is standing water.
The exact cause ( causes )without further investigation is not posable.
Improper Grade, Downspouts terminating to close, Plumbing leak, evidence of past flooding, supply line leak, neighbor clearing off his Pool cover ect.
As you stated you already have an offer on the property ( No Home Inspection )
your options are limited.
If you are unwilling or can't perceive the value of a Home Inspector might ask a Foundation Company to take a look.
Good luck with Your Purchase.
12-07-2011, 09:27 PM #3
First, get a home inspector.
2nd, no one is going to be able to tell you a lot from just photos.
3rd, get a home inspector.
You can get a company like B-Dry or Master Dry (in the East TN area) to look at it.
It could come from poor grading, defective gutters/downspouts/drains, leaking pipes, or high water table during heavy rains. In the Knoxville area we have already had over 50" of rain this year, with more to come.
Get a home inspector.
12-07-2011, 09:43 PM #4
John,
As the others have already said, the source is difficult to determine without more information. In my area, we have a fair amount of clay soil. The clay soil does not drain well and most homes have some level of moisture under them during the rainy season. Assuming that the issue is drainage, I would get someone who knows drainage. A home inspector can give some direction, but will likely defer to a drainage expert. Here in CA, we do not have a license for drainage contractors, so this often falls under the landscape or grading contractor classification.
12-08-2011, 06:43 AM #5
John, A "waterproofing" contractor will most likely try to sell you something - even if there are other less expensive alternatives are available that you could perform yourself. Also, in my view, you can make a crawl or basement less susceptible to water entry but to say it can be waterproofed is pure marketing and nothing more.
12-08-2011, 11:39 AM #6
Bruce Breedlove
www.avaloninspection.com
12-08-2011, 11:43 AM #7
Realtor recommended three. The guy I used was the cheapest of the three ;-)
12-08-2011, 11:50 AM #8
12-08-2011, 12:12 PM #9
12-08-2011, 12:16 PM #10
It is not hard to keep water out of a crawl space but it may not be cheap to fix. Based on houses I have inspected that had water in the crawlspace you are looking at anywhere between $1500-$4000 depending on what is done. I inspected 1915 house yesterday that was a swamp underneath and they are looking at upwards to $8000 to fix the water infiltration problem plus repair the damage to the wood and brickwork that the water infiltration contributed to.
12-08-2011, 12:54 PM #11
12-08-2011, 02:57 PM #12
John, I'm seriously interested in what made you hire your inspector. A lot of inspectors have many years of experience and training under their belts and like to get paid accordingly. But too often people shop for inspectors based upon price only - trying to convince them otherwise can be a challenge. What would have convinced you to go with a higher priced inspector?
12-08-2011, 04:28 PM #13
We have had a bunch of water in TN the past few weeks. What part of TN is the house in?
This is my wet crawl find for the week!
12-08-2011, 04:33 PM #14
East Tn. Scott that looks like a wet mess. That can't be normal regardless of rain...
12-08-2011, 05:19 PM #15
Bruce Breedlove
12-08-2011, 06:05 PM #16
by the way he only $30 dollars cheaper.
12-08-2011, 06:43 PM #17
12-08-2011, 07:10 PM #18
If you are near Knoxville, I would be happy to come take a look at it.
12-08-2011, 07:15 PM #19
How could anyone miss that much water during an inspection? Anyway, if that crawl was as wet in July as it is 5 months later, I'd be curious about underground springs in the area. I've seen areas that were soild clay 18 inches below the surface with a swift current of water flowing atop the clay. Good Luck.
12-08-2011, 07:17 PM #20
12-08-2011, 10:22 PM #21
The OP has deleted all his posts. Maybe he didn't like what we had to tell him. Now anyone reading this thread will have no idea what we are talking about.
Bruce Breedlove
12-08-2011, 10:38 PM #22
12-08-2011, 10:42 PM #23
12-09-2011, 07:18 AM #24
You did not just say that
You are one of the first that defends my typical spiel about realtor referrals.
Just saying, and being kind this wonderful Friday morning.
I hope all of you have a wonderful day. I also hope the majority of you folks have a ringing phone instead of one that you have to keep checking, as of late, just to see if it is still working.
12-09-2011, 11:01 AM #25
12-09-2011, 01:24 PM #26
I bet the OP was the inspector that missed the water problem.
12-09-2011, 02:53 PM #27
He not only deleted OP but also changed his Location from Tennessee to Nebraska !
12-09-2011, 03:17 PM #28
12-09-2011, 05:16 PM #29
12-10-2011, 12:00 PM #30
12-10-2011, 01:36 PM #31
Maybe each of us should make it a practice to quote these posts just in case the OP decides to delete their posts, at least that way the rest of the posts can still be followed, and ...
... what they think will be "secret" will still be public.
Sure is a waste of time to reply to posts and then have the person asking the questions delete their questions.
