Thread: In wall insulation
12-09-2011, 10:52 AM #1
In wall insulation
Southern Ca. home with no in wall insulation.
What kind of insulation is best use in exterior walls that are not insulated with out removing interior dry wall ?
12-09-2011, 02:23 PM #2
Re: In wall insulation
12-09-2011, 05:03 PM #3
Thanks Scott. Is one better then the other?
12-09-2011, 05:21 PM #4
Urea formaldadyde was found to be very bad when it was curing in people's walls. I doubt that you find anyone using it in the Golden State.
Cellulose is used fairly often for insulating old walls in my area.
12-09-2011, 09:38 PM #5
Thanks John.
02-03-2012, 05:30 PM #6
If there are any leaks or moisture accumulation within the wall ... you will wish you had used spray foam and not cellulose ... just something to think about as cellulose WILL HOLD MOISTURE and WILL SUPPORT the growth of that stuff most people freak out over ... "mold".
02-04-2012, 07:52 AM #7
The other option is a dense pack cellulose at 3.5 lbs/cu ft.
