Thread: Basement romex.
12-12-2011, 08:43 PM #1
Basement romex.
In the basement, I have romex running thru the floor joist's from the breaker box. Can I run from a junction box above to an outside wall and down to an outlet. I plan on using romex clips secured to the concrete wall with anchors, to keep the romex tight to the wall. Will this instalation be okay?
12-12-2011, 09:20 PM #2
12-12-2011, 09:25 PM #3
Re: Basement romex.
12-13-2011, 08:43 PM #4
Re: Basement romex.
Thanks for the reply. I'll just run down the wall w/ MC. Thanks again.
12-15-2011, 05:31 AM #5
Re: Basement romex.
Personally I'd use EMT or Wiremold raceways. If you're going to use AC/MC don't forget your bushings and make sure to get the right fittings for your transitions and boxes.
