Results 1 to 30 of 30
Thread: What would you do
01-19-2012, 12:12 AM #1
01-19-2012, 02:12 AM #2
Re: What would you do
Potentially you have claims against all three parties involved - the builder, the original (engineer) inspector and the HI. However, compensation for your loss - which has yet to be fully established - is partially being borne by the HI's insurance. If you have existing observable loss/damage then your own Home Owner's insurance policy should cover damage resulting from improper or lack of installation. The HI's insurance would probably limit their liability to installation of vapor barrier material, which is what he reported as being present when it wasn't. You mentioned the engineer/inspector examined certain aspects of the home, primarily in its construction. His liability may be limited by the scope of the inspection requirements, i.e. if he's not specifically checking for a vapor barrier as a common practice or SOP, then he may not be liable if one is not present.
Both your own Home Owners Ins. co. and the HI's Errors and Omissions ins. co. will be looking, I suspect, to mitigate their loss and may well serve notice/claim themselves against the other third parties. Often referred to as limited and apportioned liability. The problem, at this moment in time, is that you have not specifically identified resulting damage. In order to do that an extensive examination and inspection of the building needs to be made by yet another inspector, preferably a court recognized 'expert'. It is simply insufficient, in law, to say that the missing vapor barrier will 'likely' cause damage, you have to prove it did. The Inspector should also say that the vapor barrier is an important and integral aspect of maintaining the building envelope. And that without it the following issues... etc. etc, occurred. Do not rely solely on the claim now in process. Arm yourself with another (thorough) inspection report, including thermal imaging and retain the services of a decent tort attorney as you may have time limitations in which to file legal action.
I know this is a hypothetical question but one which has to be asked...What would you have said if your HI had reported the lack of vapor barrier during his inspection? Would that have made a difference to you in purchasing the home? Your response may well factor into any settlement you may have with the insurance companies involved. Oh, and take lots of time/date stamped pictures yourself of the existing attic condition.
Sorry to hear of your plight and good luck..
01-19-2012, 05:41 AM #3
Your home insurance policy likely does not cover damages due to construction defects. The policy details should be read to ascertain what is and is not covered.
Do not expect a pay out by inspectors insurance even though he admitted liability.
Ditto engineers insurance.
The onus is on you to prove they were negligent per established sop and standard of care, and damage and a loss have been incurred by you.
At this point in time you need to record communications with the parties involved, and take pictures of the damage.
Contact a lawyer ASAP, and begin to mitigate your losses.
01-19-2012, 05:43 AM #4
Tom,
You will find that all parties involved will be pointing their finger at the other person. Legal move. Going back on the builder is a start, if still in business. Including the Engineer Inspector for builder is another facet as well as the Home Inspector into the fight will get things really stirred up. Going after them jointly might get you a judgement on one that will cause that person to go after the others.
The Engineer's argument has some validity depending on what stage he inspected the vapor barrier. Argument is after I inspected the build must have removed the vapor barrier. Though it does not make any sense why the builder would have removed it once installed. Engineer is just covering his liability cost.
Builder has no real defense.
Home inspector might end up biting the bullet and then go after builder. But he still has liability for saying that barrier was there.
If at any point you say that you would have purchased the home without the barrier you will have removed liability from all others that are involved. I do not think that you would have waived the barrier if you were informed as to consequences.
Some of the other issues are the amount of insulation in the attic and the ventilation of the attic. Also, the moisture in the home. To much interior humidity will cause icing in the attic. Additional insulation and additional ventilation may be a resolution to the problem. Worked for a house in Maine with icing in attic.
Bottom line, you will need to get an attorney to get the attention of the other parties. Start filing actions against the inspectors and builder. Also start complaint actions with the licensing boards if you have them by your attorney.
Be prepared for a protracted fight. Consider the costs of the litigation in relation to the benefits.
Call mike Holmes, he likes this type of stuff. A lot of finger pointing.
Good luck.
01-19-2012, 11:40 AM #5
Here's another possibility. There may be a partially installed vapor barrier.
For example, I can dig away some insulation and find a vapor barrier, then I will report that it was present, but that does not in any way prove that the barrier is complete. Maybe a section is missing where you looked, but present in other areas where an inspector looked? Just saying it is possible.
If the ceiling is knotty pine nailed to the joists, it is certainly negligible not to have a vapor barrier installed in Alaska. If that's the case, it is back to the builder. Gross negligence.
But a diligent inspection is needed first to determine what was done. Walls also need to be checked. Good luck with it.
01-22-2012, 02:59 AM #6
Time for an attorney. I'm sure there are legal protections in Alaska preventing your homeowners insurance company 'dropping' you, especially if a claim is pending. They may well elect not to renew the policy when the current period ends. You may want to start a claim, just to be on the safe side but an attorney would give better legal advise.
01-22-2012, 10:21 AM #7
Yes it sounds like gloom and doom but, I'm betting it is not a total loss. Not knowing anything about homes in Alaska I'm kind of shooting in the dark, but the basics do not change that much on homes. Keep in mind that if you hire a builder or an inspector and they know that you already have problems and that there is a good chance that this will end up in court then their reports are going to be on the extreame side.
The electrical can be taken care of, switch breakers out, add the anti corrosive paste, etc.. Plumbing is just a matter of getting a good plumber in to take care of the problems.
The vapor barrier is one thing that I don't know how it is done in Alaska. In my area I would not see a vapor barrier in the attic, if it is not blown-in fiberglass or cellulose then the barrier is on the bottom at the ceiling.
Is the insulation batt or blown-in insulation in the attic?
As for what is in the walls; if you have no drywall and just wood T&G boards nailed to the studs then I would remove some planks to see what is up in the way of a vapor barrier. If you do not find a barrier then it can be installed, by removing the planks and adding it.
Yes, it will take time and you will need to move out of the home for the repairs but I have seen many homes with major problems and very, very rare that they are a complete loss or tear down.
I do a good amount of EW work on construction defects and also for lawsuits against home inspectors. It sounds like you are on the right track, but you need a good attorney who works in construction litigation. It sounds like you have a good case, but it also sounds like this might take a while to litigate. You need to be prepared for this to take a year or two to come to a resolution if not longer. All parties involved need to be named in the action, including the engineer that the builder used.
Good luck...
FYI, they will not drop you insurance coverage and foreclose on the home. The bank does not want to own your home! Most likely Alaska has a state insurance pool or some type of coverage for folks that can not get insurance through the normal channels, most states have this. You need to calm down and call an attorney and let them do the work. If you home has all of the problems you have stated, I'm betting that once a lawsuit is filed folks will start to scramble for a settlement to keep it from going to court.
01-23-2012, 06:18 AM #8
Does your state allow lawyers to work under contingency based fees?
01-23-2012, 06:49 AM #9
Did I miss something? Did your inspector not admit the error and turn it over to his insurance carrier? I had a claim against me and turned it straight to the insurance co. They satisfied the client and I paid my deductible just like it was supposed to work. Did I miss something in the conversation?
JLMathis
01-23-2012, 07:19 AM #10
Jeffrey,
In your case did you admit liability?
01-23-2012, 08:04 AM #11
Tom, I'll toss in a couple of questions. You mention the absence of a vapor barrier. Barriers are often confused with retarders such as kraft paper. Are the baths fans vented directly to the exterior through dedicated discharge points and do you use them? How is the attic's ventilation? Are there soffit vents and can you see daylight through them in the attic? Do you have enough ventilation? What humidity levels do you keep in the home? How many people live there?
I'm not saying that your problem is other than what you've presented but for me there are other considerations as well. Even when everything in the attic is correct I have seen them be overwhelmed by excessive dampness in the living areas. Any building is comprised of many components and systems which can interact which each other and often you have to broaden you view to get a true picture of what's going on.
02-06-2012, 03:20 PM #12
Don't hang you hat much on not having a signed agreement, they are more of a bluffing tool and just a bump in the road for most attorneys! Good luck, it sound like you are moving it the right direction. You still need to find an attorney, maybe once they know an insurance company is involved they will take their fee from any settlement or proceeds.
02-06-2012, 07:05 PM #13
Wow! I've never seen anything like these pics show. Sorry to hear you have to deal with this. Somebody's insurance/E&O provider is going to have to dig deep on this.
02-29-2012, 03:48 PM #14
You might want to do a little research on ABS pipe.
02-29-2012, 03:55 PM #15
Make sure to slope all pipes so that water does not collect in them.
03-01-2012, 04:51 PM #16
You shouldn't need to drain water out of you vent pipe. The plumbing is not done right, on top of your other problems.
Any moisture that collects in the vent stack thru the roof should flow by gravity back to a drain stack.
03-01-2012, 05:21 PM #17
Also, the vent pipes should be protected from freezing, using insulation or heat tape or both.
03-01-2012, 05:22 PM #18
Yes I know the venting and drains are all wrong this was a temp repair waiting to see what the home inspectors insurance company is going to do. Cant do any final repairs yet. Had a estimate by a plumber and an electrician plumbing repairs $4180.00 electric 7859.00.
03-01-2012, 05:37 PM #19
A little word of advice... If it was me and I had problems like this and I was thinking about litigation to recoup damages, I would be very cautious as to what I was posting on a public discussion board.
As an EW one of the first things I do when researching a case is to look and see what I can find on the Internet about the issue, home and person!
03-01-2012, 07:26 PM #20
Scott,makes a valid point,be careful what you post,if this is going to be a legal matter.
What ever you state publicly,may be held against you,when it goes to court.
03-01-2012, 09:14 PM #21
lol solved
03-01-2012, 09:36 PM #22
03-02-2012, 04:55 AM #23
Interesting how some turn and bite the helping hand.
03-02-2012, 06:11 AM #24
03-02-2012, 10:35 AM #25
That's a two way street.
If I were a lawyer I'd be checking out those who do EW on the internet to see how they conduct themselves on forums such as this.
03-02-2012, 11:00 AM #26
03-02-2012, 12:58 PM #27
Tom Christensen
What would you do
Posted by: Tom Christensen
Ian Page
Potentially you have claims against all three parties involved..."
Raymond Wand
Your home insurance policy likely does not cover damages due to..."
Garry Sorrells
"Tom, You will find that all parties involved will be pointing their finger..."
01-19-2012, 10:43 AM
John Kogel
"Here's another possibility..."
01-22-2012, 01:11 AM
Ian Page
"Time for an attorney..."
Scott Patterson
"Yes it sounds like gloom and doom..."
01-22-2012, 11:16 AM
Raymond Wand
"Does your state allow..."
Jeffrey L. Mathis
"Did I miss something? Did..."
Raymond Wand
"Jeffrey, In your case did you admit..."
Eric Barker
"Tom, I'll toss in a couple..."
01-23-2012, 09:15 AM
Scott Patterson
"Don't hang you hat much..."
02-06-2012, 06:34 AM
Nick Ostrowski
"Wow! I've never seen anything like these pics..."
This was from Google's cache of http://www.inspectionnews.net/home_i...ld-you-do.html It is a snapshot of the page as it appeared on Feb 24, 2012 21:13:43 GMT.
Now there is some sense of the topic discussion as it evolved.
Last edited by H.G. Watson, Sr.; 03-02-2012 at 01:28 PM. Reason: corrected form formatting of quotes.
03-02-2012, 01:18 PM #28
03-02-2012, 01:31 PM #29
03-03-2012, 10:11 AM #30
