Results 1 to 2 of 2
    john manta's Avatar
    john manta Guest
    Default Can I use pvc in a Chicago two flat?
    Hi, just purchased a two unit in Chicago. I want to replace all plumbing pipes. I am told I can't use pvc in Chicago and if I go the section 8 route, their inspectors won't approve pvc in the apartments? thanks
    Jul 2010
    Kansas City Missouri
    Default Re: Can I use pvc in a Chicago two flat?
    The Section 8 HQS inspection does not address the type of material used for plumbing supply pipes. However the local PHA may have something in their administrative plan that was approved by HUD which defines the type of materials that can be used in that jurisdiction.
    Galen L. Beasley
    Inspections Supervisor
    Housing Authority of Kansas City MO
