Results 1 to 11 of 11
Thread: PLUMBING
    victor carter's Avatar
    victor carter Guest
    Default PLUMBING
    how is pex tubing to use in new house construction and how many problems does it have?
    Default Re: PLUMBING
    Quote Originally Posted by victor carter View Post
    Welcome Victor,
    Pex has a Very Good Past Performance Record.
    * Proper Design, Fittings and Installation by knowledgeable Tradesmen is the key.
    In my experience - if there's a manibloc, it's almost never installed in accordance with manufacturer's instructions.
    It works fine as long as the folks installing it know what they are doing and following the very specific and detailed installation guidelines. I would say that about 95% of the new homes being built in my area have PEX in them. Copper is just too expensive.
    May 2010
    No. San Diego Co., CA
    PEX or Polyethelene pipe is used widely throughout the US in both residential and commercial applications. There were some issues, primarily with the connections/fittings which have been largely resolved since around 2000.
    Do not confuse PEX with PB (Polybutyl pipe) which had similar application use but with significantly more problems. Keep the PEX out of sunlight before, during and after installation. Use good quality fittings and a licensed, experienced installer. In water supply, PEX pipe is typically installed Red for hot, blue for cold. PB pipe is typically gray in color.
    PEX is usually easier to install than rigid copper and costs less. Fittings cost more but fewer are used because of the pipe's flexibility.
    Tom Thompson's Avatar
    Tom Thompson Guest
    In California and I would guess other warmer locations, rodents have been commonly known to chew threw the piping wall. Never heard of this with copper.
    May 2010
    Being that PEX was only approved for general use since 2009 in CA, and the local AHJ have final approval, I haven't seen too much of it. However, it is certainly gaining in popularity, especially with the cost of copper increasing almost daily and its ease of installation. I can't say that I have encountered any rodent issue. Never-the-less, being that PEX is obviously softer and more easily chewable than copper, rodent damage is a possibility. However, I have not read or heard of that being an issue at large and rodents are not limited to warmer climes.
    I do see quite a bit of PB pipe - a similarly malleable material but even then not witnessed a significant rodent problem with it.
    I was not professing my preference, PEX over copper, just responding to the OPs question. Certainly copper has advantages but not exclusionary.
    Quote Originally Posted by Tom Thompson View Post
    In the Tampa area, the water eats copper out from the inside out ... haven't heard of that with PEX.
    Jerry, what is it about the water down there that corrodes out copper pipes?
    Nick,
    Phosphates.
    That area is a major phosphate mining area, that stuff is all over the place, and the water filters through that stuff, picking up various chemicals which eat the copper out.
    http://www.scgov.net/environmentalse...PinHoleFAQ.pdf
    Problems with Pinhole Leaks in Your Copper Water Pipes | Science Matters | US EPA
    John Muller's Avatar
    John Muller Guest
    Thanks Ian Page I will use PEX in my house.
