Thread: Bathroom Drain Vent
04-02-2012, 06:27 PM #1
Bathroom Drain Vent
I've been noticing a foul smell when I turn on the water in our second bathroom. I looked under the sink, and the drain vent comes up higher than the trap, but the vertical vent pipe ends under the sink with a slotted cone cover over the end of the vent. Aren't drain vents supposed to tie into the vent stack that goes up to above the roof, and tie in at a point higher than the the level of the sink?
04-02-2012, 06:45 PM #2
Re: Bathroom Drain Vent
You are describing an Air Admittance Valve (AAV).
From your description, I would say that it was: a) installed wrong; b) not installed correctly; c) installed not as it should have been installed; d) or is defective and needs to be replaced.
Usually, from my experience, d) is caused by a), b), or c).
04-03-2012, 03:40 AM #3
If it is black then it is the wrong AAV. and has failed.
Replace with code accepted AAV.
04-03-2012, 04:42 AM #4
Many times small insects like spiders get caught in the seal of the valve, with most of the AAV's I have dealt with you can unscrew the top of the valve and flush them out with water.
