Thread: residential code question
04-19-2012, 12:58 PM #1
can I act as my own contractor for my own remodeling, repairs, construction, on my own residential property, w/o a contract's license in san jose, ca for example termite issues.
04-19-2012, 03:19 PM #2
Re: residential code question
Whether the question is "Can" or "May" ... the answer is the same:
Probably not, considering with your self-declared history - linked and quoted (with my own highlighting, bolding, underlining and color for emphasis) further below.
Based upon the foregoing, IMO, you do not have the ability ("can") to do so. If you are under decree, order, or consent most certainly not ("may"). Without a legally submitted application/plan and acquired permit and inspection process, again, likely not ("shall").
Check with the permiting authority of your jurisdiction, the State (CLB), and follow up with an attorney licensed to practice law in your jurisdiction.
http://www.inspectionnews.net/home_i...onversion.html
04-20-2012, 07:56 PM #3
I don't know California laws, but owner-built single houses are allowed in B.C., Canada. Owner-builders are exempt from licensing, but they need to provide third-party new home insurance when they sell the house within 10 years. These provisions hold the owner-builder personally responsible to subsequent purchasers for any defects in material, labour or design for 10 years after first occupancy. See details at:
http://www.richmond.ca/__shared/asse...its_196134.pdf
Homeowners | Homeowner Protection Office
04-21-2012, 06:18 AM #4
It is all San Jose,CA dependent. Simply H.G. Has no idea as I do not either. Make a call to the local code enforcement office they will set you straight.
It is all location dependent and varies within a State.
Licensed has no correlation to ability. Permits do not correlate to quality.
