    Jamie B's Avatar
    Jamie B Guest
    Default Horizontal Crack in Basement Wall
    My wife and I are planning on purchasing my in-laws house as he has moved into a retirement home.
    Going over the house this last weekend I came across a horiz. crack going around the perimeter of the basement. Right at about outside ground level. So far it does not seem to be bowing in but I will be taking a level out this weekend to check.
    When my wife asked my father in law about it he stated it has been there since he moved in 20 years ago and has no problems with water or anything else related to it.
    I have attached a small image of the crack. Any suggestions on this situation? We are getting a great deal on the house so if it is a real problem we will be stuck dealing with it.
    Any suggestions or feedback is greatly appreciated.
    Default Re: Horizontal Crack in Basement Wall
    Horizontal cracks are generally bad news and indicate a failure. Once the crack develops the wall has lost its designed integrity to resist pressure from the outside soil. Before you tear into fixing the wall you should look at why the wall failed and correct that cause.
    Apr 2009
    Melbourne, FL
    Eric is right, also this doesn't look like a small crack. Before you proceed you best invest in the opinion of a structural engineer the cost of correcting the problem can be devastating. Good luck!
    Quote Originally Posted by Jamie B View Post
    It depends on if you believe your father in law.
    If it HAS been like that for 20 years, it likely will not change very much.
    Note
    It will not get better over time, it can only stay the same or get worse.
    Even if it does not change any for another 20 years, when you sell the house the new buyers will have a concern about it also.
    To ascertain if the crack is stable measurements would have to be taken with a micrometer and recorded or glass slides spanning the crack, epoxied in place.
    While the crack is at grade level and less severe then further down the wall the condition none the less warrants investigation because an inspection is just a snap shot in time versus the age of the crack.
    First, that is not a small crack.
    Second cracks that run the way you stated this one runs are indicative of a more serious issue. It does not matter if it has been there unchanged for years. You should have it examined by a specialist in basement repair and/or an engineer who specializes in the same area.
    http://www.jjeffzehnder.com/
