Results 1 to 9 of 9
Thread: Rotten bathroom floor
05-07-2012, 10:16 AM #1
First time home buyer. I found a house which seems to have rotten bathroom floor. Can someone please help? Thank you very much.
The floor is cracked and appears to settlement. Is this a serious problem? How difficult and expensive is it to repair? Can it be a DIY project?
Thank you very much!
05-07-2012, 02:24 PM #2
Re: Rotten bathroom floor
It certainly can be. Hard to say without seeing it.
Hire a local inspector, there are many other components you'll want inspected.
Dom.
05-07-2012, 04:40 PM #3
05-07-2012, 05:53 PM #4
Yep. Your local home inspector can help.
He can go out and see things up close and personal.
You really need someone to look at it up close and personal - i.e., at the house, someone like your local home inspector.
05-08-2012, 10:49 AM #5
Thank you all for help. Looks like it's difficult to tell unless taking the floor out to see the damage underneath. I might have to pass this house as it's hard to estimate the repair cost and effort.
Thank you all again.
05-08-2012, 10:57 AM #6
05-08-2012, 01:45 PM #7
I've sometimes seen when removing plumbing access panels behind a tub that the floor joists beneath the tub and bathroom floor have been excessively notched to route the drain and supply lines. Could be a possible reason for all the cracked tiles.
05-08-2012, 04:26 PM #8
05-13-2012, 03:57 PM #9
I'll have to pass this house, found several more problems, other than the bathroom, the other floor is bouncing too, there are water leaks in the kitchen ceiling, the attic above is wet with black mold. And maybe there are hidden problem. Will cost a lot too repair all this. Thanks all for your help.
