Thread: Removing old asbestos siding
06-14-2012, 07:51 AM #1
Is it appropriate to saw off asbestos shingle(s) along bottom of crown molding? I would think you need to remove molding and remove asbestos.
06-14-2012, 04:05 PM #2
Re: Removing old asbestos siding
No, its not appropriate to saw asbestos shingles, it creates way too much dust (fiber release).
06-14-2012, 08:25 PM #3
You can saw,sand, grind, do whatever you want if you take the right precautions and are certified in asbestos abatement.
Sorry, I didn't see that this was a homeowner question. No, you don't want to do that. The EPA will give you 30 days in the electric chair.
The good news is, from the ads I see on TV, your survivors can get a ton of money from the Mesothelioma funds!!!
Also a little curious, why are there shingles below the crown molding? Is your house built inside out?
END GLOBAL WHINING
06-15-2012, 06:52 PM #4
You can remove your own siding.
Here's how
Check with local authorities, of course, but this gives you a general idea.
Chad
06-17-2012, 09:12 PM #5
Chad,
Your link has to do with flooring, not siding. Interior and exterior removal is quite different.
